Printer IP changed
Posted: Fri May 09, 2025 5:37 pm
by tomha
My SV08 printer had its ip address changed. Where do I change the IP address of the printer with out deleting the printer and re adding it? The support team had to send me the printer profile, since S3D says I needed to upgrade the latest version of S3D.
Tom
Re: Printer IP changed
Posted: Thu May 15, 2025 10:28 am
by S3D-Jason
You can just run the connection wizard and it will either locate the printer at the new IP automatically (if the machine supports it) or you can enter the new IP manually. There's no way to edit an old printer, so typically people setup a static IP for their machines so that they can always access them at the same IP.
Posted: Mon Jul 28, 2025 6:25 am
by G666
SOLUTION
Close the Simplify3D program
Find the Simplify3D folder inside your; USER - AppData - Local folder structure (for Win10 anyway)
Theres a subfolder called Devices
In there is one (at least) XML file per device
Open that file in a Text Editor, search for the OLD IP address, edit/over-write the new IP, save file.
Restart the program
