Page 1 of 2
FLSun T1 Pro Fan Control not working
Posted: Thu Jul 10, 2025 6:00 pm
by BikeWazowski
Hi All!
S3D Support won't help since I won't pay them for a v5 upgrade, lol.
I just setup an FLSun T1 Pro Delta and S3D 4.1.1 and the layer cooling fan control isnt' working.
I set the values in the slicer, slice the file, check the gcode and the commands are there, but it doesn't control the printer during the print.
I have layer 1 speed to 0 and layer 5 speed to 50%.
At the layer one line in the GCode I see M106 S0
At layer five I see M106 S128
When the print runs the fan ramps to 100% and never changes unless i manually adjust via the printer's control screen.
Help?!
Re: FLSun T1 Pro Fan Control not working
Posted: Thu Jul 10, 2025 7:15 pm
by parallyze
BikeWazowski wrote:FLSun T1 Pro Delta
just a guess - but is that printer running a klipper based firmware? If so, might some macros interfere with your cooling settings?
Maybe you can slice a simple item (box) and share the gcode?
bye,
para
Posted: Fri Jul 11, 2025 8:44 am
by BikeWazowski
You may be onto something. It is running Klipper. here is a simple box code:
; G-Code generated by Simplify3D(R) Version 4.1.1
; Jul 11, 2025 at 8:42:57 AM
; Settings Summary
;   processName,FLSUN GRIPS
;   applyToModels,Calibration Box 202020
;   profileName,FLSUN QQ Delta (modified)
;   profileVersion,2019-01-15 08:00:00
;   baseProfile,
;   printMaterial,TPU GRIPS
;   printQuality,Medium
;   printExtruders,
;   extruderName,Primary Extruder
;   extruderToolheadNumber,0
;   extruderDiameter,0.5
;   extruderAutoWidth,0
;   extruderWidth,0.53
;   extrusionMultiplier,1.09
;   extruderUseRetract,1
;   extruderRetractionDistance,1.6
;   extruderExtraRestartDistance,0
;   extruderRetractionZLift,1
;   extruderRetractionSpeed,3600
;   extruderUseCoasting,0
;   extruderCoastingDistance,0.2
;   extruderUseWipe,0
;   extruderWipeDistance,5
;   primaryExtruder,0
;   layerHeight,0.25
;   topSolidLayers,6
;   bottomSolidLayers,6
;   perimeterOutlines,4
;   printPerimetersInsideOut,1
;   startPointOption,3
;   startPointOriginX,300
;   startPointOriginY,0
;   sequentialIslands,0
;   spiralVaseMode,0
;   firstLayerHeightPercentage,100
;   firstLayerWidthPercentage,100
;   firstLayerUnderspeed,1
;   useRaft,0
;   raftExtruder,0
;   raftTopLayers,3
;   raftBaseLayers,2
;   raftOffset,3
;   raftSeparationDistance,0.14
;   raftTopInfill,100
;   aboveRaftSpeedMultiplier,0.3
;   useSkirt,1
;   skirtExtruder,0
;   skirtLayers,1
;   skirtOutlines,3
;   skirtOffset,4
;   usePrimePillar,0
;   primePillarExtruder,999
;   primePillarWidth,12
;   primePillarLocation,7
;   primePillarSpeedMultiplier,1
;   useOozeShield,0
;   oozeShieldExtruder,999
;   oozeShieldOffset,2
;   oozeShieldOutlines,1
;   oozeShieldSidewallShape,1
;   oozeShieldSidewallAngle,30
;   oozeShieldSpeedMultiplier,1
;   infillExtruder,0
;   internalInfillPattern,Rectilinear
;   externalInfillPattern,Rectilinear
;   infillPercentage,0
;   outlineOverlapPercentage,15
;   infillExtrusionWidthPercentage,100
;   minInfillLength,5
;   infillLayerInterval,1
;   internalInfillAngles,45,-45
;   overlapInternalInfillAngles,0
;   externalInfillAngles,45,-45
;   generateSupport,0
;   supportExtruder,0
;   supportInfillPercentage,30
;   supportExtraInflation,0
;   supportBaseLayers,0
;   denseSupportExtruder,0
;   denseSupportLayers,0
;   denseSupportInfillPercentage,70
;   supportLayerInterval,1
;   supportHorizontalPartOffset,0.3
;   supportUpperSeparationLayers,1
;   supportLowerSeparationLayers,1
;   supportType,0
;   supportGridSpacing,4
;   maxOverhangAngle,45
;   supportAngles,0
;   temperatureName,Primary Extruder,Heated Bed
;   temperatureNumber,0,0
;   temperatureSetpointCount,2,1
;   temperatureSetpointLayers,1,2,1
;   temperatureSetpointTemperatures,220,205,40
;   temperatureStabilizeAtStartup,1,1
;   temperatureHeatedBed,0,1
;   fanLayers,1,5
;   fanSpeeds,0,50
;   blipFanToFullPower,0
;   adjustSpeedForCooling,0
;   minSpeedLayerTime,15
;   minCoolingSpeedSlowdown,20
;   increaseFanForCooling,0
;   minFanLayerTime,45
;   maxCoolingFanSpeed,100
;   increaseFanForBridging,0
;   bridgingFanSpeed,100
;   use5D,1
;   relativeEdistances,0
;   allowEaxisZeroing,1
;   independentExtruderAxes,0
;   includeM10123,0
;   stickySupport,1
;   applyToolheadOffsets,0
;   gcodeXoffset,0
;   gcodeYoffset,0
;   gcodeZoffset,0
;   overrideMachineDefinition,1
;   machineTypeOverride,1
;   strokeXoverride,183.8
;   strokeYoverride,183.8
;   strokeZoverride,370
;   originOffsetXoverride,91.9
;   originOffsetYoverride,91.9
;   originOffsetZoverride,0
;   homeXdirOverride,0
;   homeYdirOverride,0
;   homeZdirOverride,1
;   flipXoverride,1
;   flipYoverride,-1
;   flipZoverride,1
;   toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
;   overrideFirmwareConfiguration,0
;   firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
;   GPXconfigOverride,r2
;   baudRateOverride,250000
;   overridePrinterModels,1
;   printerModelsOverride
;   startingGcode,G28 ; home all axes
;   layerChangeGcode,
;   retractionGcode,
;   toolChangeGcode,
;   endingGcode,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,G28 ; home all axes,M84 ; disable motors
;   exportFileFormat,gcode
;   celebration,0
;   celebrationSong,Star Wars
;   postProcessing,
;   defaultSpeed,1800
;   outlineUnderspeed,1
;   solidInfillUnderspeed,1
;   supportUnderspeed,1
;   rapidXYspeed,12000
;   rapidZspeed,12000
;   minBridgingArea,50
;   bridgingExtraInflation,0
;   bridgingExtrusionMultiplier,1
;   bridgingSpeedMultiplier,1
;   useFixedBridgingAngle,0
;   fixedBridgingAngle,0
;   applyBridgingToPerimeters,0
;   filamentDiameters,1.75|1.75|1.75|1.75|1.75|1.75
;   filamentPricesPerKg,46|46|46|46|46|46
;   filamentDensities,1.25|1.25|1.25|1.25|1.25|1.25
;   useMinPrintHeight,0
;   minPrintHeight,0
;   useMaxPrintHeight,0
;   maxPrintHeight,0
;   useDiaphragm,0
;   diaphragmLayerInterval,20
;   robustSlicing,1
;   mergeAllIntoSolid,0
;   onlyRetractWhenCrossingOutline,1
;   retractBetweenLayers,0
;   useRetractionMinTravel,1
;   retractionMinTravel,3
;   retractWhileWiping,0
;   onlyWipeOutlines,0
;   avoidCrossingOutline,0
;   maxMovementDetourFactor,200
;   toolChangeRetractionDistance,12
;   toolChangeExtraRestartDistance,-0.5
;   toolChangeRetractionSpeed,600
;   externalThinWallType,0
;   internalThinWallType,0
;   thinWallAllowedOverlapPercentage,2
;   singleExtrusionMinLength,0.2
;   singleExtrusionMinPrintingWidthPercentage,50
;   singleExtrusionMaxPrintingWidthPercentage,200
;   singleExtrusionEndpointExtension,0.2
;   horizontalSizeCompensation,0
G90
M82
M106 S0
M140 S40
M190 S40
M104 S220 T0
M109 S220 T0
G28 ; home all axes
; process FLSUN GRIPS
; layer 1, Z = 0.250
T0
G92 E0.0000
G1 E-1.6000 F3600
; feature skirt
; tool H0.250 W0.530
G1 Z1.000 F12000
G1 X10.325 Y-7.206 F12000
G1 Z0.250 F12000
G1 E0.0000 F3600
G92 E0.0000
G1 X10.325 Y7.206 E0.8653 F1800
G1 X7.206 Y10.325 E1.1302
G1 X-7.206 Y10.325 E1.9955
G1 X-10.325 Y7.206 E2.2604
G1 X-10.325 Y-7.206 E3.1258
G1 X-7.206 Y-10.325 E3.3906
G1 X7.206 Y-10.325 E4.2560
G1 X10.325 Y-7.206 E4.5208
G1 X9.795 Y-6.986 F12000
G92 E0.0000
G1 X9.795 Y6.986 E0.8390 F1800
G1 X6.986 Y9.795 E1.0775
G1 X-6.986 Y9.795 E1.9164
G1 X-9.795 Y6.986 E2.1550
G1 X-9.795 Y-6.986 E2.9939
G1 X-6.986 Y-9.795 E3.2324
G1 X6.986 Y-9.795 E4.0714
G1 X9.795 Y-6.986 E4.3099
G1 X9.265 Y-6.767 F12000
G92 E0.0000
G1 X9.265 Y6.767 E0.8126 F1800
G1 X6.767 Y9.265 E1.0248
G1 X-6.767 Y9.265 E1.8374
G1 X-9.265 Y6.767 E2.0495
G1 X-9.265 Y-6.767 E2.8621
G1 X-6.767 Y-9.265 E3.0743
G1 X6.767 Y-9.265 E3.8869
G1 X9.265 Y-6.767 E4.0990
G92 E0.0000
G1 E-1.6000 F3600
; feature inner perimeter
G1 Z1.250 F12000
G1 X3.145 Y3.145 F12000
G1 Z0.250 F12000
G1 E0.0000 F3600
G92 E0.0000
G1 X-3.145 Y3.145 E0.3777 F1800
G1 X-3.145 Y-3.145 E0.7554
G1 X3.145 Y-3.145 E1.1330
G1 X3.145 Y3.145 E1.5107
G1 X3.675 Y3.675 F12000
G92 E0.0000
G1 X-3.675 Y3.675 E0.4413 F1800
G1 X-3.675 Y-3.675 E0.8827
G1 X3.675 Y-3.675 E1.3240
G1 X3.675 Y3.675 E1.7653
G1 X4.205 Y4.205 F12000
G92 E0.0000
G1 X-4.205 Y4.205 E0.5050 F1800
G1 X-4.205 Y-4.205 E1.0100
G1 X4.205 Y-4.205 E1.5149
G1 X4.205 Y4.205 E2.0199
; feature outer perimeter
G1 X4.735 Y4.735 F12000
G92 E0.0000
G1 X-4.735 Y4.735 E0.5686 F1800
G1 X-4.735 Y-4.735 E1.1373
G1 X4.735 Y-4.735 E1.7059
G1 X4.735 Y4.735 E2.2745
; feature solid layer
G1 X2.552 Y-2.695 F12000
G92 E0.0000
G1 X2.695 Y-2.552 E0.0121 F1800
G1 X2.695 Y-1.803 E0.0571
G1 X1.803 Y-2.695 E0.1328
G1 X1.053 Y-2.695 E0.1778
G1 X2.695 Y-1.053 E0.3172
G1 X2.695 Y-0.304 E0.3622
G1 X0.304 Y-2.695 E0.5652
G1 X-0.446 Y-2.695 E0.6102
G1 X2.695 Y0.446 E0.8769
G1 X2.695 Y1.195 E0.9219
G1 X-1.195 Y-2.695 E1.2522
G1 X-1.945 Y-2.695 E1.2972
G1 X2.695 Y1.945 E1.6912
G1 X2.695 Y2.694 E1.7362
G1 X-2.695 Y-2.695 E2.1938
G1 X-2.695 Y-1.945 E2.2388
G1 X1.945 Y2.695 E2.6328
G1 X1.195 Y2.695 E2.6778
G1 X-2.695 Y-1.195 E3.0081
G1 X-2.695 Y-0.446 E3.0531
G1 X0.446 Y2.695 E3.3198
G1 X-0.304 Y2.695 E3.3648
G1 X-2.695 Y0.304 E3.5678
G1 X-2.695 Y1.053 E3.6128
G1 X-1.053 Y2.695 E3.7522
G1 X-1.803 Y2.695 E3.7972
G1 X-2.695 Y1.803 E3.8729
G1 X-2.695 Y2.552 E3.9179
G1 X-2.552 Y2.695 E3.9300
; layer 2, Z = 0.500
M104 S205 T0
G1 Z0.500 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G1 X2.695 Y2.552 F12000
G92 E0.0000
G1 X2.552 Y2.695 E0.0121 F1800
G1 X1.803 Y2.695 E0.0571
G1 X2.695 Y1.803 E0.1328
G1 X2.695 Y1.053 E0.1778
G1 X1.053 Y2.695 E0.3172
G1 X0.304 Y2.695 E0.3622
G1 X2.695 Y0.304 E0.5652
G1 X2.695 Y-0.446 E0.6102
G1 X-0.446 Y2.695 E0.8769
G1 X-1.195 Y2.695 E0.9219
G1 X2.695 Y-1.195 E1.2522
G1 X2.695 Y-1.945 E1.2972
G1 X-1.945 Y2.695 E1.6912
G1 X-2.694 Y2.695 E1.7362
G1 X2.695 Y-2.694 E2.1938
G1 X1.945 Y-2.695 E2.2388
G1 X-2.695 Y1.945 E2.6328
G1 X-2.695 Y1.195 E2.6778
G1 X1.195 Y-2.695 E3.0081
G1 X0.446 Y-2.695 E3.0531
G1 X-2.695 Y0.446 E3.3198
G1 X-2.695 Y-0.304 E3.3648
G1 X-0.304 Y-2.695 E3.5678
G1 X-1.053 Y-2.695 E3.6128
G1 X-2.695 Y-1.053 E3.7522
G1 X-2.695 Y-1.803 E3.7972
G1 X-1.803 Y-2.695 E3.8729
G1 X-2.552 Y-2.695 E3.9179
G1 X-2.695 Y-2.552 E3.9300
; layer 3, Z = 0.750
G1 Z0.750 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
; layer 4, Z = 1.000
G1 Z1.000 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
; layer 5, Z = 1.250
M106 S128
G1 Z1.250 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
; layer 6, Z = 1.500
G1 Z1.500 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
; layer 7, Z = 1.750
G1 Z1.750 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
; layer 8, Z = 2.000
G1 Z2.000 F12000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G92 E0.0000
G1 E-1.6000 F3600
; layer end
G28 ; home all axes
; Build Summary
;   Build time: 0 hours 1 minute
;   Filament length: 104.9 mm (0.10 m)
;   Plastic volume: 252.40 mm^3 (0.25 cc)
;   Plastic weight: 0.32 g (0.00 lb)
;   Material cost: 0.01
Posted: Fri Jul 11, 2025 9:13 am
by parallyze
BikeWazowski wrote: Fri Jul 11, 2025 8:44 am You may be onto something. It is running Klipper.
Looks good as far as I can tell. Maybe you'd like to check the printer configuration somewhat closer, maybe there's
some kind of M106 macro or print start/end settings inside the printer.cfg to be found. Not owning a FLSun T1 Pro
or running Klipper on my printers, so there's not much more I can suggest, I'm afraid...
Edit: If you have a working Slicer set up for the T1 Pro you might also want to check out which maros are invoked and
used. They might also be responsible for proper autolevelling and so on. Look for things like "START_PRINT" inside the
gcode file from a slicer which you know works well with that printer.
Cheers,
para
Posted: Fri Jul 11, 2025 9:20 am
by BikeWazowski
Thanks, I'll keep digging. I forgot to mention i compared the fan control commands to a file sliced with Orca (that worked) and it matched the S3D slice, so its gotta be something else.
Posted: Fri Jul 11, 2025 9:49 am
by parallyze
BikeWazowski wrote: Fri Jul 11, 2025 9:20 am Thanks, I'll keep digging. I forgot to mention i compared the fan control commands to a file sliced with Orca (that worked) and it matched the S3D slice, so its gotta be something else.
That's interesting... would you mind adding a simple orca gcode?
Posted: Fri Jul 11, 2025 10:22 am
by BikeWazowski
Orca: (split in two, first half)
; HEADER_BLOCK_START
; generated by OrcaSlicer 2.3.0 on 2025-07-11 at 10:18:42
; total layer number: 19
;_GP_TOTAL_LAYER_NUMBER_PLACEHOLDER
; filament_density: 1.22
; filament_diameter: 1.75
; max_z_height: 4.75
; HEADER_BLOCK_END
; THUMBNAIL_BLOCK_START
; thumbnail begin 48x48 436
; iVBORw0KGgoAAAANSUhEUgAAADAAAAAwCAYAAABXAvmHAAABDklEQVR4Ae3ULQ7CQBCG4TkDQSAIhs
; OgUDgcDosjqJ4Az2lLSrJku7C/3Z39JpkvqX+fTloinU6n823/eo6r42EgiZvi7UcMZAp148UgfOEu
; AhKSEg95jdxwKMSS+K6QWuFdEC3iWT7w0O8R/hpc4U0QPeKrQHqHL0IgxduIKITzQ61+DfTw4DV2w1
; 1MvHm2j9v4BWyul1ESYn0+fZ4ZwDzoEBPvBaAi7PAowCBQIP/iowCEa0wfqi9+BkhBcENC4T/xKQjO
; axTF51wDNrznNarGc14j60NthSiFNHvrpRCot94Kwf7WcxEhCER8KsRGwIXnIKDj7fkQ8OH2UgGEvB
; iApMwFkMQZAOl0Op1vb7TWegGAb/nuAAAAAElFTkSuQmCC
; thumbnail end
; THUMBNAIL_BLOCK_END
; thumbnail begin 300x300 2988
; iVBORw0KGgoAAAANSUhEUgAAASwAAAEsCAYAAAB5fY51AAAIhklEQVR4Ae3bMY4rRRiF0YoRESIgQC
; RkSARI7IGIiIyMjJQMEc0KyFntQwP4yW+YfmO7q7v+W3WOdBcwdvenUsnTGgAAAAAAAAAAAAAAAAAA
; AAAAAAAAAAAAAAAAAAAAAAAAAAAAANT32Y8/PDWAyr7+6893l4kWUNZ1rIQLKGkrVKIFlHJLrK6jJV
; zA6Z7Dc0+snLaAIR4NlWgBp+oRK+ECDtU7VKIFHOLIWAkX0MWei3XRAk5zdqheRku4gJuMjJXTFnCT
; KqESLeCjKsZKuIAPjLhYFy3gbimhehkt4YKFJJ2qnLZgYUlREi1YWFKMhAsWlRQf0YKFJUWnR7SECw
; LNcLHutAULSIrLkdESLiguKSpnhasBtSRFRLRgYUnxEC5Y1MoX66IFQZIiUTFawgUnSYpD9XA14BhJ
; MRAtWFhSBIQLFpX00osWLCzpZZ8pWsIFd/BzhRrhasDHJb3UogULS3qZhQsWlfTyihYsLOmlNeFiUS
; 7WRQsiJL2cth0t4WJ6SS+l3RauBrNJeglNtFhY0stnwsWikl42Ey0WlvSSWf9oCRcR/FzBLhMtSkt6
; meyciRYlJb1Edv6EixKSXhobO9FiqKSXxWrMhTync7FueydanCLppbDac9riUEkvg+VMtOgq6eG3zI
; kWXSQ99JY/4eIhLtZt1ESLuyQ93DbnXMjzJqcqqzbR4lVJD7GtNdHiA0kPr6074Vpc0sNq9jzRWlTS
; Q2p2PRfyC3GxbrNMtCaX9DCa3TLRmlTSQ2h274RrEkkPndmeiVa4pIfNrNeEK4yLdVt9ohUi6aEyO3
; J+/lBc0sNkdtZEq5ikh8dsxESriKSHxmz0hGuQpIfErNJE62RJD4dZxbmQP4GfK5j1nWgdJOkhMEua
; aHWW9OWbpU64dkr6ss1mmGg9KOlLNpttwnUjF+tmNSZab0j6Ms1WmJ8/bEj6Es1Wm2j9J+lLM1t5y0
; cr6csys3+3XLhcrJtlb5loJX0pZra9qS/knarM5tx00Ur68M3s/k0TraQP3cz2LTZcSR+ymfVbXLSS
; Plwz67+IC3kX62Z2vbLRSvoQzey8lTttJX14ZjZmw6OV9GGZ2fgNi1bSh2RmtXZauFysm1mPHR6tpA
; /DzOrvsAv5pA/BzLLWLVpJf7SZ5W53tJL+WDObYw+F69Pvv3v66un3qD/UzLL3+c8/vfvk22+e2r2e
; g/XFr7+8e46WcJnZ0XuO1e5gXSZaZnbEvvzjt/ex6hYspy0z673rUHUPltOWmfXaa7E6JFiiZWaPbi
; tUhwZLuMzs3r0Vq8ODJVpm9tZeXqwPDZYLeTPb2q2hOjVYTltmdr17TlXDgiVaZvZIqIYFS7jM1t2e
; WA0NlmiZrbO9oSoRLBfyZvOvV6xKBMtpy2zOPXqxHhEspy2zedY7VCWD5bRllr+jYlU2WKJllrcjQ1
; U+WMJllrMzYhURLNEyq7sjLtbjg3WJlnCZ1dmZoYoLltOWWZ2NiFVksETLbNxGhSo6WMJldv5Gxyo+
; WKJldvwqhGqaYF2iJVxm/VcpVtMEy2nLrO/O/rnCksESLbP9qxiqaYMlXGaPr3Kspg6WaJndvuqhWi
; JYwmX29lJitUywRMvs/6t6sS5YV9ESLrOsU9WywXLaMsuN1cPBepYUKNEyyw7VZW2PpEAJl628pCgd
; EquZwiVaNusSL9YPC9Vs0RIum2lJUTo1VrNEy2nLZtgMp6rDYzVTuETLUpcUpOGhmilawmVpS4pSqV
; jNFC7RsupLClLZUF1LCtRWtITLKi4pShGxupYUKactqzw/VzhJUqCctqzikqIUHauLpEA5bVmlJUVp
; ilhdSwqUaNnIJQVpulBdSwqUcNmIJUVp6lhdSwqUaNkZc7FeXFKgtqIlXNZjSVFaMlYXSYFy2rLe83
; +AoZICJVrWY0lBEqpXJAVKuGzPkqIkVm9ICpRo2T1LCpJQ3SEpUFvREi67XlKUxOoBSYFy2rKtuVhf
; TFKgRMuulxQkoeooKVDCZWLFP5ICJVprLilIQnWCpEAJ11pLipJYnSwpUKI19/wfIDdJCtRWtIQre0
; lREqsCkgLltDXXkqIkVsUkBUq0spcUJKEqLClQwpW5pCiJVYikQIlWxpKCJFSBkgK1FS3hqrGkKIlV
; sKRAOW3Vm/8DZIikQIlWjSUFSagmlBQo4Rq7pCiJ1eSSAiVa5y4pSEK1kKRAbUVLuMRKrBaTFCmnrW
; Pm/wCJkhQop62+S4qSWPFeUqCctsRKrPhHUqBES6jAaWviJUVJrLhLUqBE6+Nzsc4SkgK1Fa3Vw5UU
; JbFit6RAOW3NdaoSKx6WFKjVo5UUJKHiMEmBWjVcSVESK06RFKhVopUUJKHidEmB2orWLOFKipJYMU
; xSoGY8bblYhwckBWqW01ZSkISKcpIClX7aSoqSWFFaUqDSopUUJKEiRlKgUsKVFCWxIlJSoKpGy/8B
; womSArUVrVHhSoqSWDGNpEBVOW0lRUmsmFJSoEZFKylIQsX0kgJ1driSoiRWLCUpUEdHKylIQsWykg
; K1Fa294UqKklixvKRA9Txt+T9ACJYUqL3RSgqSUMGGpEA9Gq6kKIkV3CApULdGKylIQgV3SgrUW+FK
; ipJYwQ5JgXptSVESKuggKVAzBasBj0mK1AzBasB+SbFKDFYD+hIssYI4giVUEEWwxAqiCJZYQRzBEi
; qIIlhiBXEES6ggimCJFcRZNVgNyLRasBqQbZVgNWAeswarAXOaLVgNmF96sBqwltRgNWBNacFqANWD
; 1QCuVQ1WA9hSJVgN4Bajg9UA7jEqWA3gUWcFqwH0cHSwGkBvvYPVAI7UK1gN4CyPBqsBjHBvsBrASL
; cGqwFUsRWsBlDRy2A1AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGC3vwFmSk/D
; hYrZeQAAAABJRU5ErkJggg==
; thumbnail end
; external perimeters extrusion width = 0.53mm
; perimeters extrusion width = 0.53mm
; infill extrusion width = 0.53mm
; solid infill extrusion width = 0.53mm
; top infill extrusion width = 0.53mm
; first layer extrusion width = 0.53mm
; EXECUTABLE_BLOCK_START
EXCLUDE_OBJECT_DEFINE NAME=Calibration_Box_202020.stl_id_0_copy_0 CENTER=0,0 POLYGON=[[-10,-10],[10,-10],[10,10],[-10,10],[-10,-10]]
M73 P0 R6
;TYPE:Custom
G21
G90
M82
G28
M140 S40
M104 S225 T0
M109 S225 T0
M190 S40
G1 Z150 F3000
G1 X-130 Y0 Z0.4
M107 T0
G92 E0
G3 X0 Y-130 I130 J0 Z0.3 E30 F2000
M73 P1 R6
G1 Z2 F2000
M73 P3 R6
G92 E0
SET_TMC_CURRENT STEPPER=extruder CURRENT=0.8
G90
G21
M83 ; use relative distances for extrusion
; filament start gcode
SET_PRESSURE_ADVANCE ADVANCE=0.12; Override pressure advance value
M106 S0
;LAYER_CHANGE
;Z:0.25
;HEIGHT:0.25
;BEFORE_LAYER_CHANGE
;0.25
G92 E0
G1 E-.4 F4200
;_SET_FAN_SPEED_CHANGING_LAYER
SET_VELOCITY_LIMIT ACCEL=10000 ACCEL_TO_DECEL=5000
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=20
; printing object Calibration Box 202020.stl id:0 copy 0
EXCLUDE_OBJECT_START NAME=Calibration_Box_202020.stl_id_0_copy_0
G1 X9.585 Y9.585 F60000
G1 Z.25 F24000
G1 E.35 F4200
;TYPE:Outer wall
;WIDTH:0.53
G1 F2400
G1 X-9.585 Y9.585 E1.02505
G1 X-9.585 Y-9.585 E1.02505
G1 X9.585 Y-9.585 E1.02505
G1 X9.585 Y9.51 E1.02104
G1 E-.3125 F4200
;WIPE_START
G1 F48000
G1 X8.585 Y9.514 E-.0875
;WIPE_END
G1 X8.475 Y-9.442 F24000
G1 E.35 F4200
;TYPE:Bottom surface
;WIDTH:0.53175
G1 F2509.935
G1 X9.442 Y-8.475 E.07337
G1 X9.442 Y-7.799 F24000
G1 F2509.935
G1 X7.799 Y-9.442 E.12468
G1 X7.123 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y-7.123 E.176
G1 X9.442 Y-6.447 F24000
G1 F2509.935
G1 X6.447 Y-9.442 E.22732
G1 X5.771 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y-5.771 E.27864
G1 X9.442 Y-5.095 F24000
G1 F2509.935
G1 X5.095 Y-9.442 E.32995
G1 X4.419 Y-9.442 F24000
M73 P4 R6
G1 F2509.935
G1 X9.442 Y-4.419 E.38127
G1 X9.442 Y-3.743 F24000
G1 F2509.935
G1 X3.743 Y-9.442 E.43259
G1 X3.066 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y-3.066 E.48391
G1 X9.442 Y-2.39 F24000
G1 F2509.935
G1 X2.39 Y-9.442 E.53522
G1 X1.714 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y-1.714 E.58654
G1 X9.442 Y-1.038 F24000
G1 F2509.935
G1 X1.038 Y-9.442 E.63786
G1 X.362 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y-.362 E.68918
G1 X9.442 Y.314 F24000
G1 F2509.935
G1 X-.314 Y-9.442 E.74049
G1 X-.99 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y.99 E.79181
G1 X9.442 Y1.667 F24000
G1 F2509.935
G1 X-1.667 Y-9.442 E.84313
G1 X-2.343 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y2.343 E.89445
G1 X9.442 Y3.019 F24000
G1 F2509.935
G1 X-3.019 Y-9.442 E.94576
G1 X-3.695 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y3.695 E.99708
G1 X9.442 Y4.371 F24000
M73 P5 R6
G1 F2509.935
G1 X-4.371 Y-9.442 E1.0484
G1 X-5.047 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y5.047 E1.09972
G1 X9.442 Y5.723 F24000
G1 F2509.935
G1 X-5.723 Y-9.442 E1.15103
G1 X-6.4 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y6.4 E1.20235
G1 X9.442 Y7.076 F24000
G1 F2509.935
G1 X-7.076 Y-9.442 E1.25367
G1 X-7.752 Y-9.442 F24000
G1 F2509.935
G1 X9.442 Y7.752 E1.30499
G1 X9.442 Y8.428 F24000
G1 F2509.935
G1 X-8.428 Y-9.442 E1.3563
G1 X-9.104 Y-9.442 F24000
M73 P6 R6
G1 F2509.935
G1 X9.442 Y9.104 E1.40762
G1 X9.104 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-9.104 E1.40762
G1 X-9.442 Y-8.428 F24000
G1 F2509.935
G1 X8.428 Y9.442 E1.3563
G1 X7.752 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-7.752 E1.30498
G1 X-9.442 Y-7.076 F24000
G1 F2509.935
G1 X7.076 Y9.442 E1.25366
G1 X6.399 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-6.399 E1.20235
G1 X-9.442 Y-5.723 F24000
G1 F2509.935
G1 X5.723 Y9.442 E1.15103
G1 X5.047 Y9.442 F24000
M73 P7 R6
G1 F2509.935
G1 X-9.442 Y-5.047 E1.09971
G1 X-9.442 Y-4.371 F24000
G1 F2509.935
G1 X4.371 Y9.442 E1.04839
G1 X3.695 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-3.695 E.99708
G1 X-9.442 Y-3.019 F24000
G1 F2509.935
G1 X3.019 Y9.442 E.94576
G1 X2.343 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-2.343 E.89444
G1 X-9.442 Y-1.667 F24000
G1 F2509.935
G1 X1.667 Y9.442 E.84312
G1 X.99 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y-.99 E.79181
G1 X-9.442 Y-.314 F24000
G1 F2509.935
G1 X.314 Y9.442 E.74049
G1 X-.362 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y.362 E.68917
G1 X-9.442 Y1.038 F24000
M73 P8 R6
G1 F2509.935
G1 X-1.038 Y9.442 E.63785
G1 X-1.714 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y1.714 E.58654
G1 X-9.442 Y2.39 F24000
G1 F2509.935
G1 X-2.39 Y9.442 E.53522
G1 X-3.066 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y3.066 E.4839
G1 X-9.442 Y3.743 F24000
G1 F2509.935
G1 X-3.743 Y9.442 E.43258
G1 X-4.419 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y4.419 E.38127
G1 X-9.442 Y5.095 F24000
G1 F2509.935
G1 X-5.095 Y9.442 E.32995
G1 X-5.771 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y5.771 E.27863
G1 X-9.442 Y6.447 F24000
G1 F2509.935
G1 X-6.447 Y9.442 E.22731
G1 X-7.123 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y7.123 E.176
G1 X-9.442 Y7.799 F24000
G1 F2509.935
G1 X-7.799 Y9.442 E.12468
G1 X-8.476 Y9.442 F24000
G1 F2509.935
G1 X-9.442 Y8.476 E.07336
; stop printing object Calibration Box 202020.stl id:0 copy 0
M106 S25
;LAYER_CHANGE
;Z:0.5
;HEIGHT:0.25
;0.5
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
G1 X-8.735 Y9.183 E-.0875
;WIPE_END
EXCLUDE_OBJECT_END NAME=Calibration_Box_202020.stl_id_0_copy_0
SET_VELOCITY_LIMIT ACCEL=30000 ACCEL_TO_DECEL=15000
SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=200
M104 S215 ; set nozzle temperature
M140 S40 ; set bed temperature
SET_VELOCITY_LIMIT ACCEL=20000 ACCEL_TO_DECEL=10000 SQUARE_CORNER_VELOCITY=500
G1 X7.776 Y7.776 Z.5 F60000
G1 E.35 F4200
SET_VELOCITY_LIMIT ACCEL=15000 ACCEL_TO_DECEL=7500 SQUARE_CORNER_VELOCITY=150
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 X-7.776 Y7.776 E.83159
G1 X-7.776 Y-7.776 E.83159
G1 X7.776 Y-7.776 E.83159
G1 X7.776 Y7.701 E.82758
G1 X8.252 Y8.252 F60000
G1 F2519.159
G1 X-8.252 Y8.252 E.88253
G1 X-8.252 Y-8.252 E.88253
M73 P9 R6
G1 X8.252 Y-8.252 E.88253
G1 X8.252 Y8.177 E.87852
G1 X8.729 Y8.729 F60000
G1 F2519.159
G1 X-8.729 Y8.729 E.93347
G1 X-8.729 Y-8.729 E.93347
M73 P9 R5
G1 X8.729 Y-8.729 E.93347
G1 X8.729 Y8.654 E.92946
G1 X9.205 Y9.205 F60000
G1 F2519.159
G1 X-9.205 Y9.205 E.98441
G1 X-9.205 Y-9.205 E.98441
G1 X9.205 Y-9.205 E.98441
G1 X9.205 Y9.13 E.9804
M73 P10 R5
G1 X9.735 Y9.735 F60000
SET_VELOCITY_LIMIT ACCEL=10000 ACCEL_TO_DECEL=5000 SQUARE_CORNER_VELOCITY=20
;TYPE:Outer wall
G1 F2519.159
G1 X-9.735 Y9.735 E1.04109
G1 X-9.735 Y-9.735 E1.04109
G1 X9.735 Y-9.735 E1.04109
G1 X9.735 Y9.66 E1.03708
G1 E-.3125 F4200
;WIPE_START
G1 F48000
G1 X8.735 Y9.664 E-.0875
;WIPE_END
G1 X6.66 Y-7.633 F60000
G1 E.35 F4200
;TYPE:Internal solid infill
;WIDTH:0.534915
G1 F2493.429
G1 X7.419 Y-6.874 E.05799
G1 X7.419 Y-6.193 E.03677
G1 X6.193 Y-7.419 E.09361
G1 X5.513 Y-7.419 E.03677
G1 X7.419 Y-5.513 E.14561
G1 X7.419 Y-4.832 E.03677
G1 X4.832 Y-7.419 E.19761
G1 X4.152 Y-7.419 E.03677
G1 X7.419 Y-4.152 E.24961
G1 X7.419 Y-3.471 E.03677
G1 X3.471 Y-7.419 E.30161
G1 X2.79 Y-7.419 E.03677
G1 X7.419 Y-2.79 E.35361
G1 X7.419 Y-2.11 E.03677
G1 X2.11 Y-7.419 E.40561
G1 X1.429 Y-7.419 E.03677
G1 X7.419 Y-1.429 E.4576
G1 X7.419 Y-.749 E.03677
G1 X.749 Y-7.419 E.5096
G1 X.068 Y-7.419 E.03677
M73 P11 R5
G1 X7.419 Y-.068 E.5616
G1 X7.419 Y.613 E.03677
G1 X-.613 Y-7.419 E.6136
G1 X-1.293 Y-7.419 E.03677
G1 X7.419 Y1.293 E.6656
G1 X7.419 Y1.974 E.03677
G1 X-1.974 Y-7.419 E.7176
G1 X-2.654 Y-7.419 E.03677
G1 X7.419 Y2.654 E.7696
G1 X7.419 Y3.335 E.03677
G1 X-3.335 Y-7.419 E.8216
G1 X-4.016 Y-7.419 E.03677
G1 X7.419 Y4.016 E.8736
G1 X7.419 Y4.696 E.03677
G1 X-4.696 Y-7.419 E.9256
G1 X-5.377 Y-7.419 E.03677
G1 X7.419 Y5.377 E.9776
G1 X7.419 Y6.058 E.03677
G1 X-6.058 Y-7.419 E1.02959
G1 X-6.738 Y-7.419 E.03677
G1 X7.419 Y6.738 E1.08159
G1 X7.419 Y7.419 E.03677
M73 P12 R5
G1 X-7.419 Y-7.419 E1.13359
G1 X-7.419 Y-6.738 E.03677
G1 X6.738 Y7.419 E1.08158
G1 X6.057 Y7.419 E.03677
G1 X-7.419 Y-6.057 E1.02958
G1 X-7.419 Y-5.377 E.03677
G1 X5.377 Y7.419 E.97759
G1 X4.696 Y7.419 E.03677
G1 X-7.419 Y-4.696 E.92559
G1 X-7.419 Y-4.016 E.03677
G1 X4.016 Y7.419 E.87359
G1 X3.335 Y7.419 E.03677
G1 X-7.419 Y-3.335 E.82159
G1 X-7.419 Y-2.654 E.03677
G1 X2.654 Y7.419 E.76959
G1 X1.974 Y7.419 E.03677
G1 X-7.419 Y-1.974 E.71759
G1 X-7.419 Y-1.293 E.03677
M73 P13 R5
G1 X1.293 Y7.419 E.66559
G1 X.613 Y7.419 E.03677
G1 X-7.419 Y-.613 E.61359
G1 X-7.419 Y.068 E.03677
G1 X-.068 Y7.419 E.56159
G1 X-.749 Y7.419 E.03677
G1 X-7.419 Y.749 E.50959
G1 X-7.419 Y1.429 E.03677
G1 X-1.429 Y7.419 E.45759
G1 X-2.11 Y7.419 E.03677
G1 X-7.419 Y2.11 E.4056
G1 X-7.419 Y2.791 E.03677
G1 X-2.791 Y7.419 E.3536
G1 X-3.471 Y7.419 E.03677
G1 X-7.419 Y3.471 E.3016
G1 X-7.419 Y4.152 E.03677
G1 X-4.152 Y7.419 E.2496
G1 X-4.832 Y7.419 E.03677
G1 X-7.419 Y4.832 E.1976
G1 X-7.419 Y5.513 E.03677
G1 X-5.513 Y7.419 E.1456
G1 X-6.194 Y7.419 E.03677
G1 X-7.419 Y6.194 E.0936
G1 X-7.419 Y6.874 E.03677
G1 X-6.66 Y7.633 E.05798
M106 S51
;LAYER_CHANGE
;Z:0.75
;HEIGHT:0.25
;0.75
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
G1 X-7.367 Y6.926 E-.0875
;WIPE_END
G1 X7.776 Y7.776 Z.75 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P14 R5
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P15 R5
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P16 R5
M73 P17 R5
M73 P18 R5
M106 S76
;LAYER_CHANGE
;Z:1
;HEIGHT:0.25
;1
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z1 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P19 R5
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P20 R5
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P21 R5
M73 P22 R5
M73 P23 R5
M106 S102
;LAYER_CHANGE
;Z:1.25
;HEIGHT:0.25
;1.25
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z1.25 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P24 R5
G1 F2519.159
M73 P24 R4
G1 F2519.159
G1 F2519.159
M73 P25 R4
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P26 R4
M73 P27 R4
M73 P28 R4
;LAYER_CHANGE
;Z:1.5
;HEIGHT:0.25
;1.5
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z1.5 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P29 R4
G1 F2519.159
G1 F2519.159
M73 P30 R4
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P31 R4
M73 P32 R4
M73 P33 R4
;LAYER_CHANGE
;Z:1.75
;HEIGHT:0.25
;1.75
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z1.75 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P34 R4
G1 F2519.159
G1 F2519.159
M73 P35 R4
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
M73 P36 R4
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P37 R4
M73 P38 R4
M73 P39 R4
;LAYER_CHANGE
;Z:2
;HEIGHT:0.25
;2
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z2 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P39 R3
G1 F2519.159
M73 P40 R3
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
M73 P41 R3
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P42 R3
M73 P43 R3
M73 P44 R3
;LAYER_CHANGE
;Z:2.25
;HEIGHT:0.25
;2.25
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z2.25 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P45 R3
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
M73 P46 R3
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P47 R3
M73 P48 R3
M73 P49 R3
;LAYER_CHANGE
;Z:2.5
;HEIGHT:0.25
;2.5
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z2.5 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P50 R3
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
M73 P51 R3
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P52 R3
M73 P53 R3
M73 P54 R3
;LAYER_CHANGE
;Z:2.75
;HEIGHT:0.25
;2.75
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z2.75 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P54 R2
M73 P55 R2
G1 F2519.159
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
M73 P56 R2
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P57 R2
M73 P58 R2
M73 P59 R2
Posted: Fri Jul 11, 2025 10:25 am
by BikeWazowski
Orca: (split in two, second half)
;LAYER_CHANGE
;Z:3
;HEIGHT:0.25
;3
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z3 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P60 R2
G1 F2519.159
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
M73 P61 R2
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P62 R2
M73 P63 R2
M73 P64 R2
;LAYER_CHANGE
;Z:3.25
;HEIGHT:0.25
;3.25
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z3.25 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P65 R2
G1 F2519.159
G1 F2519.159
M73 P66 R2
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
;LAYER_CHANGE
;Z:3.5
;HEIGHT:0.25
;3.5
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z3.5 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P69 R1
M73 P70 R1
G1 F2519.159
G1 F2519.159
M73 P71 R1
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P72 R1
M73 P73 R1
M73 P74 R1
;LAYER_CHANGE
;Z:3.75
;HEIGHT:0.25
;3.75
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z3.75 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
G1 F2519.159
M73 P75 R1
G1 F2519.159
G1 F2519.159
M73 P76 R1
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P77 R1
M73 P78 R1
G1 X6.738 Y7.419 E1.08159
G1 X-7.419 Y-6.057 E1.02959
M73 P79 R1
G1 X-.068 Y7.419 E.5616
G1 X-7.419 Y.749 E.5096
G1 X-1.429 Y7.419 E.4576
G1 X-7.419 Y2.79 E.03677
G1 X-2.79 Y7.419 E.3536
;LAYER_CHANGE
;Z:4
;HEIGHT:0.25
;4
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z4 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P80 R1
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P81 R1
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P82 R1
M73 P83 R1
M73 P84 R1
;LAYER_CHANGE
;Z:4.25
;HEIGHT:0.25
;4.25
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z4.25 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P85 R1
M73 P85 R0
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P86 R0
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
M73 P87 R0
M73 P88 R0
M73 P89 R0
;LAYER_CHANGE
;Z:4.5
;HEIGHT:0.25
;4.5
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z4.5 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P90 R0
G1 F2519.159
G1 F2519.159
G1 F2519.159
M73 P91 R0
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;WIDTH:0.534915
G1 F2493.429
;LAYER_CHANGE
;Z:4.75
;HEIGHT:0.25
;4.75
G92 E0
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 X7.776 Y7.776 Z4.75 F60000
G1 E.35 F4200
;TYPE:Inner wall
;WIDTH:0.53
G1 F2519.159
M73 P95 R0
G1 F2519.159
G1 F2519.159
M73 P96 R0
G1 F2519.159
;TYPE:Outer wall
G1 F2519.159
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
G1 E.35 F4200
;TYPE:Top surface
;WIDTH:0.534914
G1 F2493.434
G1 X7.633 Y-6.66 E.07436
G1 X7.633 Y-5.979 F60000
G1 F2493.434
G1 X5.979 Y-7.633 E.12636
G1 X5.298 Y-7.633 F60000
M73 P97 R0
G1 F2493.434
G1 X7.633 Y-5.298 E.17836
G1 X7.633 Y-4.618 F60000
G1 F2493.434
G1 X4.618 Y-7.633 E.23036
G1 X3.937 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y-3.937 E.28236
G1 X7.633 Y-3.257 F60000
G1 F2493.434
G1 X3.257 Y-7.633 E.33436
G1 X2.576 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y-2.576 E.38636
G1 X7.633 Y-1.895 F60000
G1 F2493.434
G1 X1.895 Y-7.633 E.43836
G1 X1.215 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y-1.215 E.49036
G1 X7.633 Y-.534 F60000
G1 F2493.434
G1 X.534 Y-7.633 E.54236
G1 X-.146 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y.146 E.59435
G1 X7.633 Y.827 F60000
G1 F2493.434
G1 X-.827 Y-7.633 E.64635
G1 X-1.508 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y1.508 E.69835
G1 X7.633 Y2.188 F60000
G1 F2493.434
G1 X-2.188 Y-7.633 E.75035
G1 X-2.869 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y2.869 E.80235
G1 X7.633 Y3.549 F60000
G1 F2493.434
G1 X-3.549 Y-7.633 E.85435
G1 X-4.23 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y4.23 E.90635
G1 X7.633 Y4.911 F60000
G1 F2493.434
G1 X-4.911 Y-7.633 E.95835
G1 X-5.591 Y-7.633 F60000
M73 P98 R0
G1 F2493.434
G1 X7.633 Y5.591 E1.01035
G1 X7.633 Y6.272 F60000
G1 F2493.434
G1 X-6.272 Y-7.633 E1.06234
G1 X-6.952 Y-7.633 F60000
G1 F2493.434
G1 X7.633 Y6.952 E1.11434
G1 X7.633 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-7.633 E1.16633
G1 X-7.633 Y-6.952 F60000
G1 F2493.434
G1 X6.952 Y7.633 E1.11434
G1 X6.272 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-6.272 E1.06234
G1 X-7.633 Y-5.591 F60000
G1 F2493.434
G1 X5.591 Y7.633 E1.01034
G1 X4.911 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-4.911 E.95834
G1 X-7.633 Y-4.23 F60000
M73 P99 R0
G1 F2493.434
G1 X4.23 Y7.633 E.90634
G1 X3.549 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-3.549 E.85434
G1 X-7.633 Y-2.869 F60000
G1 F2493.434
G1 X2.869 Y7.633 E.80234
G1 X2.188 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-2.188 E.75034
G1 X-7.633 Y-1.508 F60000
G1 F2493.434
G1 X1.508 Y7.633 E.69834
G1 X.827 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y-.827 E.64635
G1 X-7.633 Y-.146 F60000
G1 F2493.434
G1 X.146 Y7.633 E.59435
G1 X-.534 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y.534 E.54235
G1 X-7.633 Y1.215 F60000
G1 F2493.434
G1 X-1.215 Y7.633 E.49035
G1 X-1.896 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y1.896 E.43835
G1 X-7.633 Y2.576 F60000
G1 F2493.434
G1 X-2.576 Y7.633 E.38635
G1 X-3.257 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y3.257 E.33435
G1 X-7.633 Y3.937 F60000
G1 F2493.434
G1 X-3.937 Y7.633 E.28235
G1 X-4.618 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y4.618 E.23035
G1 X-7.633 Y5.299 F60000
G1 F2493.434
G1 X-5.299 Y7.633 E.17835
G1 X-5.979 Y7.633 F60000
G1 F2493.434
G1 X-7.633 Y5.979 E.12636
G1 X-7.633 Y6.66 F60000
G1 F2493.434
G1 X-6.66 Y7.633 E.07436
G1 E-.3125 F4200
;WIPE_START
G1 F48000
;WIPE_END
M106 S0
;TYPE:Custom
; filament end gcode
M107 T0
M104 S0
M104 S0 T1
M140 S0
G92 E0
G91
G1 E-1 F2100
G1 Z+0.5 F6000
M73 P100 R0
G28
G90
M73 P100 R0
; EXECUTABLE_BLOCK_END
; filament used [mm] = 883.38
; filament used [cm3] = 2.12
; filament used [g] = 2.59
; total filament used [g] = 2.59
; total filament cost = 0.00
; total layers count = 19
; estimated printing time (normal mode) = 6m 36s
; estimated first layer printing time (normal mode) = 13s
; CONFIG_BLOCK_START
; accel_to_decel_enable = 1
; accel_to_decel_factor = 50%
; activate_air_filtration = 0
; activate_chamber_temp_control = 0
; adaptive_bed_mesh_margin = 0
; adaptive_pressure_advance = 0
; adaptive_pressure_advance_bridges = 0
; adaptive_pressure_advance_model = "0,0,0\n0,0,0"
; adaptive_pressure_advance_overhangs = 0
; additional_cooling_fan_speed = 70
; alternate_extra_wall = 0
; auxiliary_fan = 0
; bbl_calib_mark_logo = 1
; bbl_use_printhost = 0
; bed_custom_model =
; bed_custom_texture =
; bed_exclude_area = 0x0
; bed_mesh_max = 99999,99999
; bed_mesh_min = -99999,-99999
; bed_mesh_probe_distance = 50,50
; before_layer_change_gcode = ;BEFORE_LAYER_CHANGE\n;[layer_z]\nG92 E0\n
; best_object_pos = 0.5,0.5
; bottom_shell_layers = 25
; bottom_shell_thickness = 0.8
; bottom_solid_infill_flow_ratio = 1
; bottom_surface_pattern = monotonicline
; bridge_acceleration = 5000
; bridge_angle = 0
; bridge_density = 100%
; bridge_flow = 1
; bridge_no_support = 0
; bridge_speed = 50
; brim_ears_detection_length = 1
; brim_ears_max_angle = 125
; brim_object_gap = 0.1
; brim_type = auto_brim
; brim_width = 5
; chamber_temperature = 0
; change_extrusion_role_gcode =
; change_filament_gcode = PAUSE
; close_fan_the_first_x_layers = 1
; complete_print_exhaust_fan_speed = 0
; cool_plate_temp = 30
; cool_plate_temp_initial_layer = 30
; cooling_tube_length = 5
; cooling_tube_retraction = 91.5
; counterbore_hole_bridging = none
; curr_bed_type = Textured PEI Plate
; default_acceleration = 30000
; default_filament_colour = ""
; default_filament_profile =
; default_jerk = 200
; default_print_profile = 0.20mm Standard @FLSun T1
; deretraction_speed = 70
; detect_narrow_internal_solid_infill = 0
; detect_overhang_wall = 1
; detect_thin_wall = 1
; different_settings_to_system = bottom_shell_layers;detect_narrow_internal_solid_infill;detect_thin_wall;enable_arc_fitting;enable_overhang_speed;ensure_vertical_shell_thickness;filter_out_gap_fill;gap_fill_target;gap_infill_speed;infill_wall_overlap;initial_layer_infill_speed;initial_layer_line_width;initial_layer_min_bead_width;initial_layer_print_height;initial_layer_speed;inner_wall_line_width;inner_wall_speed;internal_solid_infill_line_width;layer_height;line_width;min_bead_width;min_feature_size;only_one_wall_first_layer;only_one_wall_top;outer_wall_line_width;outer_wall_speed;precise_outer_wall;reduce_crossing_wall;role_based_wipe_speed;rotate_solid_infill_direction;seam_gap;sparse_infill_density;sparse_infill_line_width;support_line_width;top_surface_line_width;wall_loops;activate_air_filtration;enable_pressure_advance;fan_cooling_layer_time;fan_max_speed;fan_min_speed;filament_flow_ratio;filament_max_volumetric_speed;filament_z_hop;full_fan_speed_layer;hot_plate_temp;hot_plate_temp_initial_layer;nozzle_temperature;nozzle_temperature_initial_layer;pressure_advance;reduce_fan_stop_start_freq;slow_down_for_layer_cooling;slow_down_layer_time;textured_plate_temp;textured_plate_temp_initial_layer;nozzle_diameter;nozzle_type;print_host;support_multi_bed_types
; disable_m73 = 0
; dont_filter_internal_bridges = disabled
; dont_slow_down_outer_wall = 1
; draft_shield = disabled
; during_print_exhaust_fan_speed = 100
; elefant_foot_compensation = 0.15
; elefant_foot_compensation_layers = 1
; emit_machine_limits_to_gcode = 0
; enable_arc_fitting = 1
; enable_extra_bridge_layer = disabled
; enable_filament_ramming = 1
; enable_long_retraction_when_cut = 0
; enable_overhang_bridge_fan = 1
; enable_overhang_speed = 0
; enable_pressure_advance = 1
; enable_prime_tower = 0
; enable_support = 0
; enforce_support_layers = 0
; eng_plate_temp = 30
; eng_plate_temp_initial_layer = 30
; ensure_vertical_shell_thickness = none
; exclude_object = 1
; extra_loading_move = -2
; extra_perimeters_on_overhangs = 0
; extruder_clearance_height_to_lid = 140
; extruder_clearance_height_to_rod = 36
; extruder_clearance_radius = 65
; extruder_colour = #26A69A
; extruder_offset = 0x0
; extrusion_rate_smoothing_external_perimeter_only = 0
; fan_cooling_layer_time = 1000
; fan_kickstart = 0
; fan_max_speed = 40
; fan_min_speed = 40
; fan_speedup_overhangs = 1
; fan_speedup_time = 0
; filament_colour = #26A69A
; filament_cooling_final_speed = 3.4
; filament_cooling_initial_speed = 2.2
; filament_cooling_moves = 4
; filament_cost = 0
; filament_density = 1.22
; filament_diameter = 1.75
; filament_end_gcode = "; filament end gcode \n"
; filament_flow_ratio = 1.08
; filament_ids = GFU99
; filament_is_support = 0
; filament_loading_speed = 28
; filament_loading_speed_start = 3
; filament_max_volumetric_speed = 5
; filament_minimal_purge_on_wipe_tower = 15
; filament_multitool_ramming = 0
; filament_multitool_ramming_flow = 10
; filament_multitool_ramming_volume = 10
; filament_notes = ""
; filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
; filament_retraction_length = 0.4
; filament_settings_id = "GRIPS TPU"
; filament_shrink = 100%
; filament_shrinkage_compensation_z = 100%
; filament_soluble = 0
; filament_stamping_distance = 0
; filament_stamping_loading_speed = 0
; filament_start_gcode = "; filament start gcode\n"
; filament_toolchange_delay = 0
; filament_type = TPU
; filament_unloading_speed = 90
; filament_unloading_speed_start = 100
; filament_vendor = Generic
; filament_z_hop = 0
; filename_format = {input_filename_base}_{filament_type[initial_tool]}_{print_time}.gcode
; filter_out_gap_fill = 98.8
; first_layer_print_sequence = 0
; flush_into_infill = 0
; flush_into_objects = 0
; flush_into_support = 1
; flush_multiplier = 0.3
; flush_volumes_matrix = 0
; flush_volumes_vector = 140,140
; full_fan_speed_layer = 5
; fuzzy_skin = none
; fuzzy_skin_first_layer = 0
; fuzzy_skin_noise_type = classic
; fuzzy_skin_octaves = 4
; fuzzy_skin_persistence = 0.5
; fuzzy_skin_point_distance = 0.3
; fuzzy_skin_scale = 1
; fuzzy_skin_thickness = 0.2
; gap_fill_target = everywhere
; gap_infill_speed = 75
; gcode_add_line_number = 0
; gcode_comments = 0
; gcode_flavor = klipper
; gcode_label_objects = 1
; has_scarf_joint_seam = 0
; head_wrap_detect_zone =
; high_current_on_filament_swap = 0
; hole_to_polyhole = 0
; hole_to_polyhole_threshold = 0.01
; hole_to_polyhole_twisted = 1
; host_type = octoprint
; hot_plate_temp = 40
; hot_plate_temp_initial_layer = 40
; idle_temperature = 0
; independent_support_layer_height = 1
; infill_anchor = 400%
; infill_anchor_max = 20
; infill_combination = 0
; infill_combination_max_layer_height = 100%
; infill_direction = 45
; infill_jerk = 500
; infill_wall_overlap = 25%
; inherits_group = "0.24mm Draft @FLSun T1";"FLSun T1 TPU";"FLSun T1 0.4 nozzle"
; initial_layer_acceleration = 10000
; initial_layer_infill_speed = 60
; initial_layer_jerk = 20
; initial_layer_line_width = 0.53
; initial_layer_min_bead_width = 100%
; initial_layer_print_height = 0.25
; initial_layer_speed = 40
; initial_layer_travel_speed = 400
; inner_wall_acceleration = 15000
; inner_wall_jerk = 150
; inner_wall_line_width = 0.53
; inner_wall_speed = 100
; interface_shells = 0
; interlocking_beam = 0
; interlocking_beam_layer_count = 2
; interlocking_beam_width = 0.8
; interlocking_boundary_avoidance = 2
; interlocking_depth = 2
; interlocking_orientation = 22.5
; internal_bridge_angle = 0
; internal_bridge_density = 100%
; internal_bridge_fan_speed = -1
; internal_bridge_flow = 1
; internal_bridge_speed = 200
; internal_solid_infill_acceleration = 15000
; internal_solid_infill_line_width = 0.53
; internal_solid_infill_pattern = monotonic
; internal_solid_infill_speed = 450
; ironing_angle = -1
; ironing_flow = 10%
; ironing_inset = 0
; ironing_pattern = zig-zag
; ironing_spacing = 0.15
; ironing_speed = 30
; ironing_type = no ironing
; is_infill_first = 0
; lattice_angle_1 = -45
; lattice_angle_2 = 45
; layer_change_gcode =
; layer_height = 0.25
; line_width = 0.53
; long_retractions_when_cut = 0
; machine_end_gcode = M107 T0\nM104 S0\nM104 S0 T1\nM140 S0\nG92 E0\nG91\nG1 E-1 F2100\nG1 Z+0.5 F6000\nG28\nG90
; machine_load_filament_time = 0
; machine_max_acceleration_e = 30000
; machine_max_acceleration_extruding = 30000
; machine_max_acceleration_retracting = 30000
; machine_max_acceleration_travel = 20000,20000
; machine_max_acceleration_x = 30000
; machine_max_acceleration_y = 30000
; machine_max_acceleration_z = 30000
; machine_max_jerk_e = 100
; machine_max_jerk_x = 20000
; machine_max_jerk_y = 20000
; machine_max_jerk_z = 10000
; machine_max_speed_e = 1000
; machine_max_speed_x = 1000
; machine_max_speed_y = 1000
; machine_max_speed_z = 1000
; machine_min_extruding_rate = 0,0
; machine_min_travel_rate = 0,0
; machine_pause_gcode = PAUSE
; machine_start_gcode = G21\nG90\nM82\nG28\nM140 S[first_layer_bed_temperature]\nM104 S[first_layer_temperature] T0\nM109 S[first_layer_temperature] T0\nM190 S[first_layer_bed_temperature]\nG1 Z150 F3000\nG1 X-130 Y0 Z0.4\nM107 T0\nG92 E0\nG3 X0 Y-130 I130 J0 Z0.3 E30 F2000\nG1 Z2 F2000\nG92 E0\nSET_TMC_CURRENT STEPPER=extruder CURRENT=0.8
; machine_tool_change_time = 0
; machine_unload_filament_time = 0
; make_overhang_printable = 0
; make_overhang_printable_angle = 55
; make_overhang_printable_hole_size = 0
; manual_filament_change = 0
; max_bridge_length = 10
; max_layer_height = 0.3
; max_travel_detour_distance = 0
; max_volumetric_extrusion_rate_slope = 0
; max_volumetric_extrusion_rate_slope_segment_length = 3
; min_bead_width = 100%
; min_feature_size = 100%
; min_layer_height = 0.08
; min_length_factor = 0.5
; min_skirt_length = 0
; min_width_top_surface = 300%
; minimum_sparse_infill_area = 15
; mmu_segmented_region_interlocking_depth = 0
; mmu_segmented_region_max_width = 0
; notes =
; nozzle_diameter = 0.5
; nozzle_height = 2.5
; nozzle_hrc = 0
; nozzle_temperature = 215
; nozzle_temperature_initial_layer = 225
; nozzle_temperature_range_high = 250
; nozzle_temperature_range_low = 200
; nozzle_type = brass
; nozzle_volume = 0
; only_one_wall_first_layer = 1
; only_one_wall_top = 0
; ooze_prevention = 0
; other_layers_print_sequence = 0
; other_layers_print_sequence_nums = 0
; outer_wall_acceleration = 10000
; outer_wall_jerk = 20
; outer_wall_line_width = 0.53
; outer_wall_speed = 75
; overhang_1_4_speed = 200
; overhang_2_4_speed = 150
; overhang_3_4_speed = 100
; overhang_4_4_speed = 50
; overhang_fan_speed = 100
; overhang_fan_threshold = 95%
; overhang_reverse = 0
; overhang_reverse_internal_only = 0
; overhang_reverse_threshold = 50%
; overhang_speed_classic = 0
; parking_pos_retraction = 92
; pellet_flow_coefficient = 0.4157
; pellet_modded_printer = 0
; post_process =
; precise_outer_wall = 1
; precise_z_height = 0
; preferred_orientation = 0
; preheat_steps = 1
; preheat_time = 30
; pressure_advance = 0.12
; prime_tower_brim_width = 3
; prime_tower_width = 60
; prime_volume = 45
; print_compatible_printers = "FLSun T1 0.4 nozzle"
; print_flow_ratio = 1
; print_order = default
; print_sequence = by layer
; print_settings_id = 0.25mm GRIPS @FLSun T1
; printable_area = 129.505x11.3302,128.025x22.5743,125.57x33.6465,122.16x44.4626,117.82x54.9404,112.583x65,106.49x74.5649,99.5858x83.5624,91.9239x91.9239,83.5624x99.5858,74.5649x106.49,65x112.583,54.9404x117.82,44.4626x122.16,33.6465x125.57,22.5743x128.025,11.3302x129.505,7.9602e-15x130,-11.3302x129.505,-22.5743x128.025,-33.6465x125.57,-44.4626x122.16,-54.9404x117.82,-65x112.583,-74.5649x106.49,-83.5624x99.5858,-91.9239x91.9239,-99.5858x83.5624,-106.49x74.5649,-112.583x65,-117.82x54.9404,-122.16x44.4626,-125.57x33.6465,-128.025x22.5743,-129.505x11.3302,-130x1.59204e-14,-129.505x-11.3302,-128.025x-22.5743,-125.57x-33.6465,-122.16x-44.4626,-117.82x-54.9404,-112.583x-65,-106.49x-74.5649,-99.5858x-83.5624,-91.9239x-91.9239,-83.5624x-99.5858,-74.5649x-106.49,-65x-112.583,-54.9404x-117.82,-44.4626x-122.16,-33.6465x-125.57,-22.5743x-128.025,-11.3302x-129.505,-2.38806e-14x-130,11.3302x-129.505,22.5743x-128.025,33.6465x-125.57,44.4626x-122.16,54.9404x-117.82,65x-112.583,74.5649x-106.49,83.5624x-99.5858,91.9239x-91.9239,99.5858x-83.5624,106.49x-74.5649,112.583x-65,117.82x-54.9404,122.16x-44.4626,125.57x-33.6465,128.025x-22.5743,129.505x-11.3302,130x-3.18408e-14
; printable_height = 330
; printer_model = FLSun T1
; printer_notes =
; printer_settings_id = FLSun T1 0.5 nozzle
; printer_structure = delta
; printer_technology = FFF
; printer_variant = 0.4
; printhost_authorization_type = key
; printhost_ssl_ignore_revoke = 0
; printing_by_object_gcode =
; purge_in_prime_tower = 1
; raft_contact_distance = 0.1
; raft_expansion = 1.5
; raft_first_layer_density = 90%
; raft_first_layer_expansion = 2
; raft_layers = 0
; reduce_crossing_wall = 1
; reduce_fan_stop_start_freq = 0
; reduce_infill_retraction = 1
; required_nozzle_HRC = 0
; resolution = 0.012
; retract_before_wipe = 30%
; retract_length_toolchange = 1
; retract_lift_above = 0
; retract_lift_below = 0
; retract_lift_enforce = All Surfaces
; retract_on_top_layer = 1
; retract_restart_extra = -0.05
; retract_restart_extra_toolchange = -0.05
; retract_when_changing_layer = 1
; retraction_distances_when_cut = 18
; retraction_length = 1
; retraction_minimum_travel = 2
; retraction_speed = 70
; role_based_wipe_speed = 0
; rotate_solid_infill_direction = 0
; scan_first_layer = 0
; scarf_angle_threshold = 155
; scarf_joint_flow_ratio = 1
; scarf_joint_speed = 100%
; scarf_overhang_threshold = 40%
; seam_gap = 15%
; seam_position = aligned
; seam_slope_conditional = 0
; seam_slope_entire_loop = 0
; seam_slope_inner_walls = 0
; seam_slope_min_length = 20
; seam_slope_start_height = 0
; seam_slope_steps = 10
; seam_slope_type = none
; silent_mode = 0
; single_extruder_multi_material = 1
; single_extruder_multi_material_priming = 0
; single_loop_draft_shield = 0
; skirt_distance = 2
; skirt_height = 1
; skirt_loops = 0
; skirt_speed = 80
; skirt_start_angle = -135
; skirt_type = combined
; slice_closing_radius = 0.049
; slicing_mode = regular
; slow_down_for_layer_cooling = 0
; slow_down_layer_time = 1000
; slow_down_layers = 0
; slow_down_min_speed = 20
; slowdown_for_curled_perimeters = 1
; small_area_infill_flow_compensation = 0
; small_area_infill_flow_compensation_model = 0,0;"\n0.2,0.4444";"\n0.4,0.6145";"\n0.6,0.7059";"\n0.8,0.7619";"\n1.5,0.8571";"\n2,0.8889";"\n3,0.9231";"\n5,0.9520";"\n10,1"
; small_perimeter_speed = 50%
; small_perimeter_threshold = 0
; solid_infill_direction = 45
; solid_infill_filament = 1
; sparse_infill_acceleration = 15000
; sparse_infill_density = 0%
; sparse_infill_filament = 1
; sparse_infill_line_width = 0.53
; sparse_infill_pattern = gyroid
; sparse_infill_speed = 550
; spiral_finishing_flow_ratio = 0
; spiral_mode = 0
; spiral_mode_max_xy_smoothing = 200%
; spiral_mode_smooth = 0
; spiral_starting_flow_ratio = 0
; staggered_inner_seams = 0
; standby_temperature_delta = -5
; start_end_points = 30x-3,54x245
; supertack_plate_temp = 35
; supertack_plate_temp_initial_layer = 35
; support_air_filtration = 1
; support_angle = 0
; support_base_pattern = rectilinear
; support_base_pattern_spacing = 2.5
; support_bottom_interface_spacing = 0.5
; support_bottom_z_distance = 0.2
; support_chamber_temp_control = 0
; support_critical_regions_only = 0
; support_expansion = 0
; support_filament = 0
; support_interface_bottom_layers = 2
; support_interface_filament = 0
; support_interface_loop_pattern = 0
; support_interface_not_for_body = 1
; support_interface_pattern = auto
; support_interface_spacing = 0.5
; support_interface_speed = 100
; support_interface_top_layers = 2
; support_line_width = 0.53
; support_material_interface_fan_speed = -1
; support_multi_bed_types = 1
; support_object_first_layer_gap = 0.2
; support_object_xy_distance = 0.35
; support_on_build_plate_only = 0
; support_remove_small_overhang = 1
; support_speed = 350
; support_style = default
; support_threshold_angle = 35
; support_threshold_overlap = 50%
; support_top_z_distance = 0.2
; support_type = tree(auto)
; temperature_vitrification = 30
; template_custom_gcode =
; textured_cool_plate_temp = 40
; textured_cool_plate_temp_initial_layer = 40
; textured_plate_temp = 40
; textured_plate_temp_initial_layer = 40
; thick_bridges = 0
; thick_internal_bridges = 1
; thumbnails = 48x48/PNG, 300x300/PNG
; thumbnails_format = PNG
; time_cost = 0
; time_lapse_gcode =
; timelapse_type = 0
; top_bottom_infill_wall_overlap = 25%
; top_shell_layers = 5
; top_shell_thickness = 0.8
; top_solid_infill_flow_ratio = 1
; top_surface_acceleration = 10000
; top_surface_jerk = 20
; top_surface_line_width = 0.53
; top_surface_pattern = monotonicline
; top_surface_speed = 250
; travel_acceleration = 20000
; travel_jerk = 500
; travel_slope = 3
; travel_speed = 1000
; travel_speed_z = 0
; tree_support_adaptive_layer_height = 1
; tree_support_angle_slow = 25
; tree_support_auto_brim = 1
; tree_support_branch_angle = 30
; tree_support_branch_angle_organic = 40
; tree_support_branch_diameter = 5
; tree_support_branch_diameter_angle = 5
; tree_support_branch_diameter_organic = 2
; tree_support_branch_distance = 5
; tree_support_branch_distance_organic = 1
; tree_support_brim_width = 3
; tree_support_tip_diameter = 0.8
; tree_support_top_rate = 30%
; tree_support_wall_count = 0
; upward_compatible_machine =
; use_firmware_retraction = 0
; use_relative_e_distances = 1
; wall_direction = auto
; wall_distribution_count = 1
; wall_filament = 1
; wall_generator = classic
; wall_loops = 5
; wall_sequence = inner wall/outer wall
; wall_transition_angle = 10
; wall_transition_filter_deviation = 25%
; wall_transition_length = 100%
; wipe = 1
; wipe_before_external_loop = 0
; wipe_distance = 1
; wipe_on_loops = 0
; wipe_speed = 80%
; wipe_tower_bridging = 10
; wipe_tower_cone_angle = 0
; wipe_tower_extra_flow = 100%
; wipe_tower_extra_spacing = 100%
; wipe_tower_filament = 0
; wipe_tower_max_purge_speed = 90
; wipe_tower_no_sparse_layers = 0
; wipe_tower_rotation_angle = 0
; wipe_tower_x = 165.000
; wipe_tower_y = 250.000
; wiping_volumes_extruders = 70,70,70,70,70,70,70,70,70,70
; xy_contour_compensation = 0
; xy_hole_compensation = 0
; z_hop = 0.4
; z_hop_types = Normal Lift
; z_offset = 0
; first_layer_bed_temperature = 40
; bed_shape = 129.505x11.3302,128.025x22.5743,125.57x33.6465,122.16x44.4626,117.82x54.9404,112.583x65,106.49x74.5649,99.5858x83.5624,91.9239x91.9239,83.5624x99.5858,74.5649x106.49,65x112.583,54.9404x117.82,44.4626x122.16,33.6465x125.57,22.5743x128.025,11.3302x129.505,7.9602e-15x130,-11.3302x129.505,-22.5743x128.025,-33.6465x125.57,-44.4626x122.16,-54.9404x117.82,-65x112.583,-74.5649x106.49,-83.5624x99.5858,-91.9239x91.9239,-99.5858x83.5624,-106.49x74.5649,-112.583x65,-117.82x54.9404,-122.16x44.4626,-125.57x33.6465,-128.025x22.5743,-129.505x11.3302,-130x1.59204e-14,-129.505x-11.3302,-128.025x-22.5743,-125.57x-33.6465,-122.16x-44.4626,-117.82x-54.9404,-112.583x-65,-106.49x-74.5649,-99.5858x-83.5624,-91.9239x-91.9239,-83.5624x-99.5858,-74.5649x-106.49,-65x-112.583,-54.9404x-117.82,-44.4626x-122.16,-33.6465x-125.57,-22.5743x-128.025,-11.3302x-129.505,-2.38806e-14x-130,11.3302x-129.505,22.5743x-128.025,33.6465x-125.57,44.4626x-122.16,54.9404x-117.82,65x-112.583,74.5649x-106.49,83.5624x-99.5858,91.9239x-91.9239,99.5858x-83.5624,106.49x-74.5649,112.583x-65,117.82x-54.9404,122.16x-44.4626,125.57x-33.6465,128.025x-22.5743,129.505x-11.3302,130x-3.18408e-14
; first_layer_temperature = 225
; first_layer_height = 0.250
; CONFIG_BLOCK_END
Posted: Fri Jul 11, 2025 10:26 am
by BikeWazowski
to meet the max char limit for posts, i deleted a bunch of random G1 code from the second half
Posted: Fri Jul 11, 2025 10:45 am
by parallyze
BikeWazowski wrote: Fri Jul 11, 2025 10:26 am to meet the max char limit for posts, i deleted a bunch of random G1 code from the second half
Interestingly there are some Klipper commands inside the orca file which aren't used with your current S3D profile. Things like
"SET_TMC_CURRENT" or "SET_PRESSURE_ADVANCE". Maybe somebody with experience in Klipper/S3D will chime in, in the meantime
I'd probably try to copy/paste the orca start/end code and replace all the prusa/orca variables with the ones used in S3D, things like
"[first_layer_bed_temperature]" (prusa/orca) vs. "[bed1_temperature]" (s3d) and so on.
Maybe the culprit are missing lines in the comments - while they're not read when parsing the file for gcode commands they will be used
in certain cases by your printer anyways, like the thumbnail blocks on top of the file (notice how they're technically comments, with a preceding ";"). Maybe it's as easy as something missing like "; EXECUTABLE_BLOCK_START" which causes the printer to not "recognize" it's in the printing process and therefore using some overrides for fans.... looking for Klipper/S3D in general and not specific to that printer model might yield some results.
