lforbes
Bambu P1S with Hardened Steel Hot end settings.
I love Simplify3D 5.1.2 but I am struggling getting the P1S to print properly with it. First of all the P1P profile doesn't have a Chamber fan but the P1S does.
Also I am using the Hardened Steel hot end and the Stainless Steel P1P settings are not working at all with it. I also have a Biqu Frostbite plate and it is great and I have reduced the bed temp to 35.
Trying to compare the settings with Bambu vs what was set for P1P for Simplify3D is difficult to tell what to change.
Does anyone else use Simplify3D with Bambu P1S and steel hot end and have any suggestions for settings to try?
S3D-Taylor
Re: Bambu P1S with Hardened Steel Hot end settings.
The Bambu P1S should use the same profile as the Bambu X1, not the P1P.
If you're using a different nozzle for your Bambu P1S printer, I believe you should change the printer settings on the printer's control screen under accessories - nozzle:
https://forum.bambulab.com/t/bambu-stud ... tion/56748
