V4 profiles moved to V5 I cannot change
Posted: Fri Oct 17, 2025 10:42 am
by Carlbosson
I can not seem to make changes to the profiles that where moved from V4 to the new V5? Did I miss something? Thanks in advance.
Carl
Re: V4 profiles moved to V5 I cannot change
Posted: Tue Oct 21, 2025 10:23 am
by S3D-Jason
What do you mean you can't make changes? If you click Edit Process Settings in V5 do you see the old profiles in the "select profile" drop down list?
Posted: Sun Oct 26, 2025 11:47 am
by Carlbosson
The old profiles from V4 are there in the drop down, and I can select them, but I can not change them. Normally when you have selected a profile and you want to change the speed, lets say. Once the change has been made the profile changes to "Modified" and the change to the speed is now reflected in the settings. This is not happening, the settings to these V4 profiles cannot be changed.
Posted: Tue Oct 28, 2025 5:01 pm
by S3D-Jason
I don't think that's something I've experienced before. I would suggest sending a quick video to our team at the link below so they can provide more suggestions:
Posted: Wed Oct 29, 2025 11:57 am
by Carlbosson
Thank you for your help. I will do this in the coming days.
Posted: Fri Nov 21, 2025 8:50 am
by Carlbosson
This issue seems to have gone away. I did nothing but now everything is working as it should. Ghost in the machine. You can mark this post as closed. Thank you
Carl
