dragon2000
QIDI Box
Hi Community,
I have a QIDI Plus 4 and a QIDI Box. I want to print multiple colours and the box holds 4 filaments. So, it should be simple Right? But I can not get it to work and change filament, or at least I don't know how to set up Simplify3D to make it work.
Does anyone have experience in using the QIDI Box for multi-filament printing and could help me?
Many thanks in advance.
ampster
Re: QIDI Box
Have you tried QIDI Studio or Orca Slicer? I have never had that printer but going by quick search showing it first became available in 2025, it might be worth sticking to manf. slicer recommendation.
tico902
Re: QIDI Box
Voici les correctifs à apporter dans Profif dans l'onglet Scrip de démarrage:
;===== BOX_PREPAR =====
SET_PRINT_SUB_STATUS SUB_STATUS=change_filament
SAVE_VARIABLE VARIABLE=enable_box VALUE=1
SAVE_VARIABLE VARIABLE=value_t0 VALUE="'slot0'"
SAVE_VARIABLE VARIABLE=value_t1 VALUE="'slot1'"
SAVE_VARIABLE VARIABLE=value_t2 VALUE="'slot2'"
SAVE_VARIABLE VARIABLE=value_t3 VALUE="'slot3'"
BOX_PRINT_START EXTRUDER=[first_tool] HOTENDTEMP=[extruder0_temperature]
M400
EXTRUSION_AND_FLUSH HOTEND=[extruder0_temperature]
Dans l'onglet Autres (Propriéte du Filament section Extruder à modifé : Inscrit Extruder 1
Dans la première onglet Extruder, Associe chaque Extruder à l'outil correspondant.
Cela devrait régler le problème
