altering the temperature setting on start up
Posted: Wed Aug 19, 2026 8:40 am
by geoffro4u
When I start a print the temperature goes to the set temp 230C then it cools down the nozzle temp to 140C before starting the print. the nozzle moves to print start point and begins printing whilst the temp builds up to the correct temp . Mean while 1/2 to 3/4 of the brim does not print due to (I guess) low temp in the extruder.
I would like to rewrite the script so that the temp drop is only 20C , not the 90C it is now.
Also I am using factory files from 3DLabPrint and when I access the Scripts button I don't get any useful script coming up to be able to edit, Is there a way to make the script visible.
Re: altering the temperature setting on start up
Posted: Wed Aug 19, 2026 3:20 pm
by S3D-Taylor
Could you attach the factory file here so we can take a look at it?
Posted: Wed Aug 19, 2026 7:01 pm
by geoffro4u
Taylor
I have no idea on how to attach a factory file to this forum, Please help. Cheers Geoff
Posted: Mon Nov 16, 2026 2:01 pm
by S3D-Jason
In Simplify3D, go to File > Save Factory File As, then choose where you want to save it.
When you make a new reply on the forum you can look right below the Submit button and you will see the Attachments tab where you can add the file.
