S3D with Da Vinci AiO
Posted: Thu Apr 09, 2015 8:45 am
by jhabr
Yesterday I bought the S3D and started to use with Da Vinci 1.0 AiO. For my surprise, I could see that there isn't the 1.0 AiO. I know that it's the same printer with scanner, but the firmware are different. I could not use some jog or bed leveling features. I'm printing with some issues, sometimes the printing sending fail, needing to boot the printer or restart the software.
AiO users, are running without any issues?
Re: S3D with Da Vinci AiO
Posted: Fri Apr 10, 2015 7:13 am
by JoeJ
Everything works except for the jogging and bed leveling, but the stock XYZprinting software doesn't support those types of manual commands either, so it makes sense. I think it's just a limitation of what they have available in the firmware, so not much S3D can do about it.
The occasional print upload failing is a known issue with many of the XYZprinting firmware versions. Make sure you have the latest firmware installed, because there was a HUGE difference in the stability of uploading on my XYZ after I updated the firmware.
Posted: Tue Apr 14, 2015 6:00 pm
by jhabr
And how about the "Edit Process Settings" for specific printing functions, such as bed and extruder temperature? This is set by the cart, right? Or the settings I put there can affect the print?
Posted: Wed Apr 15, 2015 6:07 am
by JoeJ
Yes, you can override the temperatures using the software. It adds a lot of capability.
Posted: Wed Apr 15, 2015 6:49 am
by SphereNoob
jhabr wrote:And how about the "Edit Process Settings" for specific printing functions, such as bed and extruder temperature? This is set by the cart, right? Or the settings I put there can affect the print?
the initial temp for bed and extruder are dictated by the specific cartridge loaded. If you choose different temperatures, the printer heat up to the temperature stored in the cartridge, then begin printing, and then go to whatever temperature you have put inside the process.
Posted: Sun Dec 11, 2016 4:53 am
by NoHands
I cant get my extruder temp above 213 with abs cartridge I don't understand how to make it go higher
Posted: Sun Dec 11, 2016 10:01 am
by brian442
Might want to make a separate thread for your question, then add your factory file there
