[ADDED] Need Speeds greater than 100 percent
Posted: Sun Apr 12, 2015 8:23 pm
by kjhuebner
When editing the settings -- on the "Other" tab -- various speeds can be set.
However, I cannot increase many of the speeds above 100 percent. Namely...
Outline Underspeed
Solid Infill Underspeed
Support Structure Underspeed
I want to increase the support structure speed to 110% but I cannot. 100% is the limit. Why?
A user should be able to speed up and slow down every type of operation (outline, infill, support structure, whatever! etc.).
This would give maximum versatility in creating fast, quality prints.
I tried a workaround of boosting the default print speed, then adjusting the underspeeds. This does not work as it throws off other portions of critical print speeds.
Ken Huebner
Product Developer
Re: Need Speeds greater than 100 percent
Posted: Mon Apr 20, 2015 8:50 am
by Vasily
+1
i think can be 500% for some prints
Example:
material: flex
regular speed: 30 mm/s
support speed can be: 50-90 mm/s (~160..300% from regular)
Posted: Tue Apr 21, 2015 9:39 am
by kjhuebner
But you're using absolute speeds (e.g., 30 mm/sec). Seems to me the percentage approach (e.g., 110%) should be supported as well, since it's more versatile.
Posted: Sun Apr 26, 2015 5:13 pm
by JWS
+1
Posted: Fri Jul 10, 2015 6:28 am
by S3D-Jason
This has been changed in version 3.0. You can now enter values greater than 100% for those options if you choose.
