Model scale export issues
Posted: Tue Apr 14, 2015 10:51 pm
Hello,
I am new to 3D printing and I need a little help with the software.
I modeled an object in Lightwave3D 11.5 to a specific scale. It is about 111mm X 60mm. In Lightwave it is correct and it looks fine. I exported to .obj and imported it into Simplify3D and it is very very very tiny. You can't even see the model on the S3D grid unless you zoom in all the way. If I scale the model up in S3D I can make it bigger but I need the scale to be exactly the same when it is printed as it was when it was modeled. One reason being that there are holes in the model that need to be an exact size because other hardware is going into them.
I have also tried exporting\importing .stl with the exact same results.
I have seen other people print Lightwave models...
does anyone have any suggestions?
Thanks,
-RW
Thanks,
-RW
