Chronic Nozzle Clogging Issues, Retraction Possible Culprit?
Posted: Wed Apr 15, 2015 3:57 pm
I'm having issues lately with any print that is taller than about 75mm and longer than around 4 hours where the extrusion starts to become very sparse and sometimes eventually just stops altogether. My printer is a Dremel Idea Builder (rebranded Flashforge Dreamer) and I've had many successful prints on it the first month of use, but this new problem has become quite chronic. I've repeatedly tried cleaning the nozzle using the Taulman "pull" technique and using some extruder floss + nozzle cleaning tool from MakerGeeks. This often remedies the issues for a little while but usually the sparse extrusion creeps back in about halfway through the next print.
I've tried a few different brands of PLA filament, all of which worked flawlessly for weeks prior. When the issue kicks in the infill seems to suffer most and gets quite spider-webby which is usually my first indication that things are going south. I even purchased a second Dremel a few weeks ago to get through a huge print rush and within a week it developed the same problem.
One thing I'm wondering is if there could be something in my print settings in Simplify that might be causing or compounding the issues. It would stand to reason if you don't have the retraction set right it could continually putting pressure on the filament feed...or even the opposite effect of retracting too much and letting residual plastic in the nozzle get carbonized. This is all pure speculation of course.
My prints are always at 100 micron and usually 3 outline layers (inside to out order), 15% fill. I've also tried variations on temp within the suggest range for each PLA with no improvement.
Any ideas or suggestions would be appreciated. Thanks.
