[ADDED] A better way of saving/loading profiles
Posted: Fri Apr 17, 2015 4:25 am
Simplify3D is a great slicer program that has the ability to perform with a wide range of printers....but for me, and I suspect for many new users, it has an enormous weakness - a horribly confusing way of storing and retreiving print settings. A scenario to illustrate what I mean....
A new user follows the instructions to get a "Process" that supports their printer and prints at 0.2 mm in PLA. They spend several hours doing test prints to get the print quality just how they want it. It's perfect...so they give it a Process Name of "PLA 0.2mm" andthen want to save it so they can move onto printing in ABS. Where's the "Save"? After realising its not "Save" but "Export", they export the profile into an .fff file and move on...
Later on, they want to load the "PLA 0.2mm" print profile back in. Where's the "Load"? Silly them...it's "Import"...and the list of possible process to import includes a long list of default printer profiles in alphabetical order with the "PLA 0.2mm" profile they want at the very bottom of the list. So, having negotiated this starnge list, they import the profile. In the Processes list it's not called "PLA 0.2mm" as they expected it to be, but its "Process2".
The above actually happened to me some months ago, but I'm now wise to this strange way of saving and loading profiles. But, can something be done about this strange way of storing and using profiles. Why not separate the "default" processes for different printers from saved processes, and make the mechanism of loading and saving exactly that. The terminology "Exporting" and "Importing" imply a means of passing data between different programs.....and the current export/import loses the process name, which to me is a duplication. Why have separate process names AND a save/export names?
Has anyone else been through this experience???
