[DONE] automatic AND manual supports
Posted: Fri Apr 17, 2015 2:02 pm
by AndersE
I don't know if it has been requested before but:
I want option to have BOTH generated supports AND manual supports. Because when there needs much supports, the automatic does not put supports
on every place it is needed, and i don't want to manually add kazillions of supports ;)
So after auto supports is made i want to be able to add some more manually.
And also i have noticed that when adding manual supports inside a model, it is impossible to do unless you can actually SEE the place to add it to inside the model.
Even if crosssection is on.
Re: req: expanded support options
Posted: Sat Apr 18, 2015 6:55 am
by JoeJ
You can already do this. It's mentioned on pretty much every tutorial or writeup of the S3D support structures (you might want to read this: https://www.simplify3d.com/support/tuto ... tructures/)
Bring up the custom support window, click "apply based on overhang angle" to place the automatic supports, then use the manual controls at the bottom of that window to add/remove additional support pillars.
Posted: Sun Apr 26, 2015 6:27 pm
by AndersE
Sorry. I missed this completely.
