Gap Fill doesn't work in some cases
Posted: Fri Apr 17, 2015 3:46 pm
Hi together,
I can print out really excelent quality with my Mankati and S3D.
Normally I have no proplems with gaps, when the walls are more than 3 mm wide.
Now I needed some parts, realy strong and solid printed, but the 2 mm walls end have a gap like the old problem with thin walls. I can look through the gap just to the table while solid boddem- and top layer 5 layers are determine.
This occures only when I taged on the Auto-ExtrusionWidth in EXTRUDER; I'm using a 0.60 mm nozzle and the Auto will calculate ExtrusionWidth 0.72
The same with Manuell ExtrusionWidth minimized to lower than 0.70 (pictures examples are 0.60) the gap will be closed and print out solid.
The difference you can see also in the print-preview as the real print out.
Is it a bug or a feature?
regards
horst.w, GER
My standasds are
Infill - 75%, Outline 25%, ExtrusionWidth 130%
Allow Gap Fill = on, overlap 50%
regards
horst.w, GER
My standasds are
