Duel extruder print with an offset on FFCP
Posted: Sun Apr 19, 2015 8:49 pm
by rforeman
On my Flash Forge Creator Pro I was trying to print a sign with both extruders, but when it switches from the right to the left it shifts the print to the left by 2.42mm.
How can I fix this?
Thanks.
Re: Duel extruder print with an offset on FFCP
Posted: Mon Apr 20, 2015 6:12 am
by JoeJ
Your toolhead offsets must be wrong in the firmware. The way that you adjust them varies depending on what firmware you have, but you will need to add 2.42mm to the X-axis offset
Posted: Mon Apr 20, 2015 7:59 am
by rforeman
JoeJ wrote:Your toolhead offsets must be wrong in the firmware. The way that you adjust them varies depending on what firmware you have, but you will need to add 2.42mm to the X-axis offset
Thats JoeJ. I finely got it fixed last night about 3am my time(USA East Coast).
