Page 1 of 2
First Layer Issues
Posted: Thu Jul 25, 2013 12:20 am
by ScootnDoodle
Hello fellow creators,
I just got my M2 a couple weeks ago and after some calibration my prints have been coming out pretty nice. However, when I slice models with Creator, my first layer is not quite solid. When I print the pre-loaded models, the first layer comes out nice n' solid with a glossy finish. I've adjusted nearly all the settings and I'm currently running tomlombardi's settings. Here's a photo of the issue:
Does anyone know whats going on?
Re: First Layer Issues
Posted: Thu Jul 25, 2013 12:38 pm
by chuck12
I can't be certain but it appears to me you are printing with the raft option turned on.
Posted: Thu Jul 25, 2013 4:58 pm
by ScootnDoodle
The raft option was off. I did have some stick issues due to printing about 5 calibration cubes before this one, however, they all had this same first layer issue.
Posted: Thu Jul 25, 2013 6:11 pm
by sir-mike
you should check your Z-zero it might be more than your layer height or your z-offset in creator is to high.
Michael
Posted: Thu Jul 25, 2013 7:33 pm
by ScootnDoodle
I just checked the z-offset, and its at 0. I'll recalibrate the z-zero for the next print, but with the current calibration, Creator sliced models printed the first layer differently than the pre-loaded.
Posted: Thu Jul 25, 2013 11:20 pm
by ScootnDoodle
For comparison, here's the glider model pre-sliced and printed with the same calibration as the calibration pyramid below it.
Posted: Thu Jul 25, 2013 11:59 pm
by jd_3d
I've had the same problem and sent the issue to the tech team. This happens when you use a manual extrusion width (which I need to control certain things). They said they are working on a fix for the next version that will use the proper path spacing for that first layer.
Posted: Fri Jul 26, 2013 12:30 am
by ScootnDoodle
This makes sense, I had a feeling it was a program issue.
I just printed a pyramid with Slic3r and it is pretty much flawless... and Slic3r is free
Posted: Fri Jul 26, 2013 6:47 am
by Clayton
This is only a problem with the very first layer and was just due to conflicting settings. For example, setting a manual extrusion width and then changing other properties that "should" affect this width (but didn't because it was manually set).
Try setting your first layer height to 100% and then using the z-offset on the G-Code tab if you want to lower the head more to squish the filament on the first layer. Or you could use auto extrusion width.
Posted: Sun Sep 08, 2013 2:25 am
by rklosinski
I have a similar issues on my M2 with abs EXCEPT i did not use the manual extrusion option. Will this be corrected or can I get a refund? My Z-height is set to .1mm and I just re-checked it.
