Extruder GCODE help
Posted: Wed May 13, 2015 11:41 pm
by fmeroney
Hi All,
Having some Gcode issues.
What I'm trying to do is purge both extruders on my MakerGear M2... however before I keep wasting PLA, let me ask you guys/girls what I'm doing wrong.
Starting script:::
M108 S255 ; turn on M2 fans
G28 ; home all axes
G1 Y50 Z0.3 F9600 ; move forward to avoid binder clips
G1 X209 Z10 ; move off platform
G1 Z0.4 ; position nozzle
G92 E0 ; zero extruder
G1 E25 F225 ; purge E0 nozzle
T1 ; Change to Extruder E1 (T1)
G1 E25 F225 ; purge E1 nozzle
T0 ; Change to Extruder E0 (T0)
G1 X190 Z0.1 E1.0 F1200 ; slow wipe
G1 X180 Z0.25 ; lift
So what it's doing is only purging Extruder 1.. doesn't do much anything else, then starts the print
Re: Extruder GCODE help
Posted: Wed May 13, 2015 11:55 pm
by BaudR8
After T1 and before the purge, do a G92 E0 (zero E value), otherwise it's trying to go to E25 from E25 (no movement)
Posted: Thu May 14, 2015 12:00 am
by fmeroney
BaudR8 wrote:After T1 and before the purge, do a G92 E0 (zero E value), otherwise it's trying to go to E25 from E25 (no movement)
Great, let me give that a go!
Thanks,
Posted: Sat May 16, 2015 6:22 pm
by fmeroney
Didn't work, however I did get it to function.
Thanks!
Posted: Mon May 18, 2015 4:56 am
by Rebekah_harper
hiya,
it didnt' work but you got it to function?
does that mean you got both nozzles to purge? if so could you share your solution as I would like to be able to do the same.
cheers
becky
Posted: Mon May 18, 2015 2:34 pm
by DarthRevan
This should work :D :
Code: Select all
G28 ; home all axes
T0
G1 X205 Z10 ; move off platform
G1 E25 F225 ; purge nozzle
; Begin Additional Purge
T1
T0
; End Additional Purge
Rebekah_harper wrote:hiya,
cheers
becky
