Placing priont on bed.
Posted: Sun May 17, 2015 2:33 pm
by simplifyguy
Hello all.
I recently moved to Simplify and I was wondering if there is a button or command that will place components on the print bed. What I mean by this is that when I load a new part it often needs to be rotated so that a flat area of the print is on the print bed. When I do the rotation, example: half sphere, I than have to manually shift the object up or down so that it mates with the bed. In Cura there is a lay flat button or when you rotate the object it plops the part onto the print bed without vertical adjustments.
How do I go about doing this here.
Re: Placing priont on bed.
Posted: Mon May 18, 2015 7:26 am
by JoeJ
Once you get it rotated how you want, you can go to Models --> drop model on table. That will adjust the Z-position so that it is touching the build table surface.
I usually just click the Center and Arrange button though, since that corrects the Z-position but also centers it
Posted: Mon May 18, 2015 9:41 am
Just to add to Joe's reply, neither of the methods he's described will make any adjustment to the rotational positioning of the object. The object is simply adjusted on the z axis so that it touches the bed.
What you really looking for is the ability to "Lay flat" an object on the bed.....which is the subject of this enhancement request: http://forum.simplify3d.com/viewtopic.php?f=23&t=1146 Adding to the thread may raise it's status......
