Bought S3D yesterday. I put in a support ticket for the table size problem yesterday and also searched the forum and also watched some S3D setup videos that deal specifically with S3D and the FF Creator. Still haven't found the fix for the problem.
Here's my setup...
Flashforge Creator Pro
Here's my problem...
S3D thinks the table is larger than it actually is and does a start cleaning extrude to the left of the table. ReplicatorG knows the table size and works correctly. I've checked the EEProm offset settings in the CreatorPro and they are correct.
I've tried the suggested startup code given on the S3D website for situations where the left extruder starts too far left of the table. The only result I saw was that the start begins somewhere in the center of the table. (X axis) Also note that both the left and right extruder start too far left of the table.
Given that ReplicatorG knows the size of the table I believe I can assume that I'm have a standard CreatorPro build table.
GIven that S3D has a default setup for the CreatorPro I should assume that the problem lies within S3D. I've also tried the Creator preset and got the same results.
I'm new to 3D printing and don't know much about G code. However my guess is that there is a line in the startup code that defines the start x,y,z position of the nozzle cleaning extrude. The initial left nozzle height movement appears to be working correctly. i.e. table comes up and left nozzel touches the back right edge of the table.
How do I fix this?
Regards,
Fred
