0.1mm layer height ignores features
Posted: Fri Aug 02, 2013 6:45 pm
Just bought Simplify 3D after Maker Faire Detroit and so far I'm loving it. One issue that I can't seem to work around is any time I change my layer height to 0.1mm the infill because crazy and the models loose features.
Attached are a working and non working gcode file, one with 0.25 layer height and one with 0.10 layer height. If you look at both of them the problem should be clear. In one you have a screw, the other turns out like some weird spring thing. I also attached my broken printer settings
