Calibrating of a CTC (Flashforge Clone)
Posted: Tue May 19, 2015 5:18 pm
by Killerkai
Hi!
I´m new to 3D Printing and did my first steps with a CTC Printer and Simplify3d 2.2.2
Today, i printed a calibration cube with 25mm each side.
Z-Heigt and X-Width is absolutely correct, but in Y-axis the Cube is only 24,4mm.
Is there a "calibration factor" i can insert for this axis in Simplify3d?
If not - What can i do?
I´m running the actual Sailfish 7.7 as Firmware on the CTC
Thanks in advance!
Kai
Re: Calibrating of a CTC (Flashforge Clone)
Posted: Wed May 20, 2015 6:02 am
by JoeJ
That's odd, because usually the X and Y axes use the exact same steps per mm values. And obviously any settings like extrusion multipliers of filament diameters would also affect both the X and Y axes. It's quite rare to see only the Y axis being off. Usually both the X and Y are off.
So in your case, if only one of the axes is off, I would suspect it is probably a hardware issue. Maybe some excessive backlash with the belts. Because I can't think of any settings in the software that would cause the X and Y axes to be different.
