How to remove a problem layer from a part?
Posted: Tue May 19, 2015 9:52 pm
I don't think this feature is available from within S3D but maybe someone could advise me of a good program to use in order to fix this problem .stl file.
Like many parts I've downloaded a lot of parts don't have a flat edge. In this particular .stl file there are a couple of partial layers on the "flat" side which screw up the part.
What's the best program to use in order to slice away these first two partial layers?
The part is attached. At first glance it appears perfectly flat, however if you add a raft you can quickly see the problem.
TIA,
Fred
Attch: Base-Top.stl
TIA,
Fred
Attch: Base-Top.stl
