Printing before Extruder reaches temp
Posted: Tue May 19, 2015 11:49 pm
Hey all,
I am fairly new at this. I can print objects with the right extruder just fine. I had some issues with the left extruder. I had to disassemble and clean a clog. After doing this a few times i found the cause... The left extruder begins to print before the temperature heats (230). This tells me it must be a problem with the settings in S3D. After doing a little research, I found a checkbox that states "Wait for temperature controller to stabilize before beginning build". I was satisfied that I solved the problem. In addition, I made the first layer print at 240 and the second 230. After I reloaded the program, I noticed the heating started earlier, but still not early enough. The first few inches began extruding around 200 and does not adhere. Is there something I am missing? Also, Why would you ever want that check box unchecked?
Thanks,
Jason
Thanks,
Jason
