The latest update to the Creator 3D printing software is now available! It boasts better compatibility, a new bed leveling wizard, and continued print quality improvements. The full list of changes is below.
- Addition of new Bed Leveling Wizard (found at Tools > Bed Leveling Wizard)
- Added support for multitouch tablet and trackpad gestures
- Added support for control boards that do not allow reset via USB (i.e. Printrboards, Gen6, etc)
- Better importing and error handling for binary STL files that disobey the format standards
- Improvements for OBJ file parsing to support a wider variety of formats
- Improved solidity for solid infill regions
- Special case improvements for 100% infill
- Smoothing improvements for raft and skirt outlines
- Speed improvements for support generation with large models
- Added maximize button to Machine Control Panel window
- Added numeric value to FFF Settings infill slider
- Better sorting for temperature and fan speed layer setpoints
- Better padding for temperature plot data so high temperature data won't be directly on the roof
- Communication improvement to allow for larger serial cache sizes
- Automated handling of communication timeouts to force a build to continue without user interaction (see Tools > Firmware Configuration, Communication tab)
- Fix for bug that was affecting some first layer extrusion widths when using manually defined values
- Fix for Z-lift retraction movements that could previously cause movements too close to print surface
- Fixed extruder coasting bug that would appear with some large coasting distances
As always, the latest update can be obtained by visiting our downloads page. Just follow the instructions in your confirmation email.
