How can I print this properly..?
Posted: Wed May 20, 2015 4:02 pm
by Mthompson
I have a 1" tall tube (3/4" inner DIA) that I print standing up. I wanted to add text cutout, but didnt get the desired outcome. So my next thought would be to still have my desired text, but since I have a FFP...use the other extruder with different color to take care of it. Not sure how to do this. Much thanks for the assistance!
Re: How can I print this properly..?
Posted: Wed May 20, 2015 4:12 pm
by Mthompson
Posted: Wed May 20, 2015 4:14 pm
by Mthompson
^^ Which would be good for a flat surface, but I want my text to wrap.
Posted: Wed May 20, 2015 5:34 pm
by Rebekah_harper
you could duplicate the model so you have 2. set them horizontally. drop them half way down so you print 2 halves with support.
then glue them together.
Posted: Thu May 21, 2015 8:25 am
by Mthompson
Problem with doing that would be that its a tube that slides over another item which has a tight tolerance and would not be 100% perfect. Thanks for the reply though
Posted: Thu May 28, 2015 4:21 pm
by DarthRevan
Are you doing this to a model you've CAD'd? If so you should be able to extrude text in your CAD software.
