Hello,
I have a problem with the Infill Extrusion Width. Am I right that it controls both, the extrusion width of the top and bottom infill layer and as well the infill between the shells?
I have the problem that when I set the Infill Extrusion Width to about 120% my top and bottom layers will look perfectly smooth but my infill is not very strong since the strings don’t bond to each other sufficiently. On the other hand if I set the value to 200% the Infill will be very strong but my top and bottom layer get a very rough surface since there is too much extrusion.
Is there an option to control the extrusion width of the top and bottom infill and the normal infill separately? Or will there be an option in the future?
Is anyone else experiencing this problem?
