Airwolf 3D XL Not working, Please Help!
Posted: Tue Aug 06, 2013 2:28 pm
by erichahn525
Has anyone had any success connecting to the Airwolf 3d XL printer with the creator software? I am unable to connect to it. Repetier talks to it perfectly fine, and prints! But creator is unable to do anything at all....
Re: Airwolf 3D XL Not working, Please Help!
Posted: Tue Aug 06, 2013 5:47 pm
by Simplify3D
What control board does the Airwolf 3D XL use? Some of the lower end boards do not support reset via USB, so if that is the case with your board you will have to go to Tools > Firmware Configuration, select the Communication tab and disable the "Wait for startup command" option.
You also need to make sure to select the correct COM port and baud rate for your printer. You may need to click the "Refresh" button for new COM ports to show up after you plug in your machine.
Posted: Tue Aug 06, 2013 5:57 pm
by erichahn525
The com port is correct, as it is the same address location that repetier uses. I've ensured to disconnect from repetier before connecting with creator. The board is a rambo board. I'll try the reset configuration and see if that works.
Posted: Wed Aug 07, 2013 10:56 am
by erichahn525
The manual reset allowed me to end up connecting, trying to find a profile for the airwolf now to print with.
