Page 1 of 2
[ADDED] What s3d is really missing are two things
Posted: Sat May 30, 2015 10:55 am
by Trax
1. Nice support for infill, honeycomb pattern
2. dual extruder support, walls to purge the extruder
Re: What s3d is really missing are two things
Posted: Wed Jun 03, 2015 9:57 am
by Michael_N
+1
Posted: Thu Jun 11, 2015 1:15 pm
by McSquid
+1. Hate the lack of dual extruder support
Posted: Thu Jun 11, 2015 6:53 pm
by bergdesign
By "walls to purge the extruder", I think you are referring to what you can do with skirt/brim under the additions tab. Turn on "Include skirt/brim", set the layers to 1, set the offset to 2 or 3 mm (or more) and set the outlines to 1. S3D will trace around your object one time before starting the first layer, purging any air gap in the hot end.
Posted: Mon Jun 15, 2015 4:12 pm
by moraesgyn
+ 1
thats like 90% of the feature requests here! I wonder when they are going to release the new version. any news on that?
Posted: Mon Jun 15, 2015 4:15 pm
by moraesgyn
bergdesign wrote:By "walls to purge the extruder", I think you are referring to what you can do with skirt/brim under the additions tab. Turn on "Include skirt/brim", set the layers to 1, set the offset to 2 or 3 mm (or more) and set the outlines to 1. S3D will trace around your object one time before starting the first layer, purging any air gap in the hot end.
I believe he is talking about the wipe tower, when there is a block meant to wipe the nozzle when the tool exchange happens.
Posted: Tue Jun 16, 2015 1:19 pm
by dennisjm
Been using S3D for a long time now. Been saying the same thing. There are plenty of threads already on the subject.
Just did another dual color print in Makerware. It worked fine. I don't even bother with S3D if I want two color/support material prints. I tried every tip/quirk/hack/suggestion for months. Every time I found cases where it just didn't work with temperature, nozzle order, or whatever. Not worth the effort when I can just use a different program.
They made a good start by adding retract distance for nozzle change events but the lack of the wiper/purge tower still results in extra wrong material all over the print.
Anyway... like I said... it's all been hashed out before on the forums but I'll
+1
anyway just because S3D is still lacking the feature :)
BTW I like S3D a lot. I use it almost exclusively.. except when I need different infill settings or dual colors :)
Posted: Mon Jun 22, 2015 10:00 am
by ale3d
+1 For the support to dual extrusion. Purge walls, prime pillars, anything that can reduce the oozing.
A skirt as tall as your object is a good workaround, but with taller prints it lacks in the structural part. Adding more skirt outlines will help with it, but will double the time and the material spent on the shield/skirt. Purge walls are a better choice for the time and the material used.
Posted: Mon Jun 22, 2015 10:29 pm
by tri-lite
Have you looked at today's posts in the "general Requests" sub-forum? Some big news! You can get a preview of what's coming in 3.0. Looks like the devs were working on ALL these things you requested, and more!
Posted: Tue Jun 23, 2015 9:38 pm
by brennanyama
+1
