Z Offset Problems
Posted: Mon Jun 01, 2015 2:46 pm
Hi all, new user here with some settings problems.
I'm using a DaVinci 1, J firmware, hacked, and the latest Simplify3D. When I brought the software I just set it up and off I went printing. The only problem I had was that I couldn't print smaller than 0.18mm for layer height. Finally this weekend I decided to have a look at this problem. I first cleaned the print bed and then re-leveled it to a factor of 245, however I now could not print below 0.25mm. When I say could not print, what happens is I get the clicking sound from the print head, meaning that the head is too low and the filament cant get out!. I re-leveled the bed, but this time to a factor of 320 and got back top the minimum print layer of 0.18. From here I tried to alter the settings in the G Code section, setting the Z value at up to .55 but it didn't seem to make any difference.
Am I right in thinking that this section is where you can increase the Z distance between the head and the printing plate or is there another setting point I should be looking at?
TIA.
TIA.
