Can't connect to Solidoodle 3
Posted: Wed Aug 07, 2013 10:18 pm
by Techbuilder
I purchased Simplify 3d and I haven't been able to connect with my solidoodle 3.
I've used the same settings on Repetier-Host which works fine there but not on Simplify 3d.
Here's what I've tried
matching the buad settings
resting the printer board controller
made sure no software was communicating with com3 which it is on aside from Simplify 3d.
I'm really running out of ideas here :(
Re: Can't connect to Solidoodle 3
Posted: Thu Aug 08, 2013 6:41 am
by Clayton
The post right below yours had a suggestion that might help. Just disable the "Wait for startup command" option.
http://forum.simplify3d.com/viewtopic.p ... =267#p1202
Posted: Thu Aug 08, 2013 12:03 pm
by Techbuilder
I'll give that a try and post my findings
thanks for the advice hopefully it will work :idea:
Posted: Sat Aug 10, 2013 2:08 pm
by Techbuilder
So that got it to connect!!
but now when it runs it goes so slow?
is there away to configure the steps per mm in this software like in repetier host?
Posted: Sat Aug 10, 2013 3:24 pm
by dalew8abz
Techbuilder,
If it's going REALLY slow, you probably copied your mm/sec values from your other software. Everything in Creator is in mm/min, so multiply by 60.
Here are the places where you set up speeds:
When you add your "Process" (FFF), double-click that to open up the FFF Settings window. The main printing speed (again, mm/min, not mm/sec!!!) is on the "Other" tab. A typical value for the M2 is 4800 mm/min (80 mm/sec). Also here you find the X/Y movement (fast move with no extrusion) speed (M2 typ. is 12000 mm/min (200 mm/sec)), and the Z move speed (lift, between layers, M2 = 1200 mm/min or 20 mm/sec). Extruder retraction speed is on the Extruder tab (M2 = 1000 mm/min).
The stuff in the Firmware Configuration and General Configuration under the Tools menu is the G-code commands used for various functions and stuff like the build envelope size. Nothing here on speeds. It's all in FFF setup. And all the other speeds are in percent of the above (like first layer speed, that sort of stuff).
Oh, one more thing: (I hope I'm correct on this!!!) I believe all the G-code values are in length and time units (mm, etc.), not steps. Everything to do with "steps" (converting mm to steps) is done in the firmware, not in Creator. You build the firmware with the steps/mm for each axis as a parameter, so the printer itself "knows" how many steps or steps/sec to move when you give it a distance or speed.
Hope this helps!
Dale
