Slanted prints
Posted: Thu Aug 08, 2013 5:52 pm
I have just started using Creator and although I can use the machine control quite easily it seems that every time I slice something in Creator and then print it it becomes slanted. When I preview the gcode everything seems fine but when I print the model turns out to be slanted in the +X direction.
I think the gcode is getting some type of cumulative error between each layer and adding on the layer height to the subsequent x layer position. I tried to slice with slic3r and print with Pronterface and it went off without a hitch so I am positive this is a creator problem.
I am using a Gen6 board with Marlin software and the latest creator release.
