DaVinciXYZ Printer shuts down during upload
Posted: Fri Jun 05, 2015 5:35 pm
by ecurbrolyat
I am using a DaVinci XYZ 1 printer. 75/100 times, during the upload of the Gcode the printer shuts down and then comes back on but will not print.
The gcode is generated ok but the problem occurs during the uploading. There appears to be something in the gcode that causes this. Strangely enough this doesn't happen all the time. Once in a while it will print ok. This will happen, even using the same STL file.
Re: DaVinciXYZ Printer shuts down during upload
Posted: Sat Jun 06, 2015 12:37 pm
by BaudR8
which operating system are you running? I have a friend who has a da vinci and he has found 100% success on his Mac by mimicking the EOL characters used by Windows. In short try this if you're encountering this with Mac:
Open the Machine Control Panel, and disconnect from the da Vinci printer. Change the baud rate to 250000 and then reconnect.
in the scripts tab, in post processing under the prepend script, put in:
{REPLACE "\n" "\r\n"}
Then slice a model. Do not upload the print, instead save the toolpaths to the disk somewhere, this will make sure the post processing scripts are run. Then go to File > Preview G-Code, and choose the file you just saved. Then try to upload that to the printer.
Posted: Tue Jun 16, 2015 2:57 pm
by ecurbrolyat
This fix seems to have fixed the problem, so far...
Thanks,
Bruce
Posted: Tue Jun 16, 2015 3:11 pm
by KeyboardWarrior
BaudR8 wrote:which operating system are you running? I have a friend who has a da vinci and he has found 100% success on his Mac by mimicking the EOL characters used by Windows. In short try this if you're encountering this with Mac:
It's funny how typewritters and 2d paper-printing conventions have come all this way effect 3d printers.
Posted: Mon Aug 17, 2015 9:44 am
by hammboned
Where do I find this? I went into "edit process settings" > "scripts" > "end scripting."
Here is what I have there:
M103 ; turn off extruder and retraction
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M107 ; turn off fan
M127 ; turn off valve
M84 ; disable motors
Am I supposed to but it at the end of this part? Sorry for my ignorance lol.
Posted: Mon Aug 17, 2015 10:27 am
by BaudR8
M107 ; turn off fan
No problem, in the Scripts tab, in the box that says "Additional post processing", add it to the bottom of that.
Posted: Mon Aug 17, 2015 7:33 pm
by hammboned
Ah... I completely overlooked that portion for some reason. Thank you for your assistance. It is much appreciated.
Posted: Sat Jan 22, 2022 5:10 am
by KVisser
Hello does this also work with a windows PC? i have the same isue on my new laptop but my old one is working fine with XYZ print!
