A few quick questions before purchase
Posted: Sat Jun 06, 2015 1:35 am
After being pretty upset with the capabilities of Makerbot's software, I just found Simplify3D yesterday and am pretty excited (and ready to click the "buy now" button) - but as there is no trial period, I was wondering whether those using it could help give me a few pointers to make sure it's what I'm after.
- I noticed that Makerbots (I have a 2X) are supported - how much tweaking is needed to set it up for my printer or is it as easy as clicking "2X" and having all the settings defaulted for me?
- I frequently use dual extrusion for dissolvable filament (which I'm hoping I won't need to use with this software), however just in case, how smooth is dual extrusion with Simplify? Is it a new buggy feature or is it fully integrated?
- How easy are rafts/brims/skirts to remove? I found rafts with the Makerbot Desktop near impossible to remove on large flat surfaces - hence the use of dissolvable. But dissolvable here is sitting over $100 per kg so I'd like to avoid it when possible
- How much material do supports use? Are they pretty lightweight and low on material usage? Do you find the supports adequate for ABS (which I have found so far sucks at making long bridges, although I'm still pretty new to this)?
- I've noticed that there are preset filament settings - will PET-G go through just fine? I imagine it will but thought I'd check anyway.
- One major pro for me is the ability to edit infill settings on different parts of the print. I imagined the Makerbot was capable of it, but cannot for the life of me figure out why this isn't doable in the software. This is really important for us as we are trying to make prints with 90 degree angles and need some solid support in areas - I want easily customizable designs and do not want to have to be editing them to trick the software into thinking places are hollow just so that I can have high and low infill areas! So, although it's okay if it can't, can Simplify3D allow you to edit "zones" of the design (eg a top right hand corner of a box) or can you only change these settings for layers?
I think that's it. I'm hoping this software can be my saviour - just ruined a print today as the Makerbot software stuck the "extrusion guards" for dual extrusion outside of the bounds on a large print - I cannot find any settings to change this (the extrusion guards are HUGE), leaving my only option to reduce the print size. I'm not a fan of having to change my print because the software has so little ability in the way of customization (including me having to put supports in outside of the software as I cannot edit the supports outside of a couple of parameters).
