Thin Wall Behavior Issues
Posted: Sun Jun 14, 2015 1:52 am
SO prior to v2.2 and this feature S3D filled all walls no matter their thickness. However since all these updates I've had to begin modeling my projects around what will slice with S3D which doesn't allow me to be as precise as I want.
Any wall under 1.50mm usually will not be filled only outlined. I've always printed at 0,20mm and 60-100% infill. However it's gotten so annoying I've considered just going back to a free slicer.
The area in question is 4mm wide 3.75mm long and a 1.35mm screw hole. using two shells per normal. Thin wall behavior set at default 10%, adjusting this does nothing. How can I get around this? If you need more settings info please let me know.
