Can't get Add Overhang based on Angle to work
Posted: Tue Jun 16, 2015 3:55 pm
by Grifftech
In the piece I am trying to print I have the overhang max set to 30degrees but the part in the image will not get any added to that front section that has about a 45 degree overhang. I have to place it manually
Re: Can't get Add Overhang based on Angle to work
Posted: Tue Jun 16, 2015 8:49 pm
by KeyboardWarrior
You may need to turn the resolution down from 4 mm to a smaller size to fit that area.
Posted: Wed Jun 17, 2015 1:32 pm
by Grifftech
KeyboardWarrior wrote:You may need to turn the resolution down from 4 mm to a smaller size to fit that area.
That was it, THANKS!!
