[SOLVED] Repeatable Failure To Print -- Early in Raft
Posted: Wed Jun 17, 2015 11:19 am
The first time this happened I thought it was a printer hardware failure. While printing the support raft the printer just stopped in the middle of a line. It did this twice, continued, slanted a couple lines into one another, then finally ran over the edge of the print and drove into a limit.
I rebooted the PC, restarted the printer, re-exported the STL, ran the STL through a checker of my own design that I've used to verify my STL files for actual stereolithography for several years, restarted Simplify3D.... and repeated precisely the identical failure in the raft at the same location three times.
MakerGen M2 V3b, S3D 2.2.2.
The STL is exported from Solidworks 2014. I've been printing versions of this part for four days now... this is the third rev. It's the eighth or ninth little fixture I've been printing, after four test parts I designed and printed that were expressly designed to exercise printer performance. I've gone through a spool of PLA that came with the printer and half way through my first spool of ABS, and aside from clogged nozzles that prevent the first layer from going down properly, this is the first failure I've seen.
Here is what the failure looked like:
http://www.ericpeterson.info/M2Files/P1000238.JPG
Here's what the preview showed when it happened:
http://www.ericpeterson.info/M2Files/P1000239.JPG
Here's the STL and factory file:
http://www.ericpeterson.info/M2Files/10 ... tiwarp.zip
The M2 is happily printing right now the last version of the fixture prior to the one that causes the failure.
- ep
- ep
