aristoxenus
cam port problem
I cannot get the software to connect with the printer. The COM port is fine in the Device Manager but will not connect.
Tom Wagner
KeyboardWarrior
Re: cam port problem
I think more information would definitely help troubleshoot this. :D :D (what printer, what O.S is your computer)?
**If the USB port shows up, but you're unable to connect, it might be selected to the wrong Baud Rate**
However, for more information on connecting, I recommend this post: viewtopic.php?f=8&t=1949
DarthRevan
aristoxenus wrote:I cannot get the software to connect with the printer. The COM port is fine in the Device Manager but will not connect.
Tom Wagner
KeyboardWarrior wrote:I think more information would definitely help troubleshoot this. :D :D (what printer, what O.S is your computer)?
It's Probably "3) (If MakerBot/Sailfish style machine) Open MakerBot Desktop, go to Services and select Stop Background Services. Background Services will connect to the printer even if MakerBot Desktop isn't open, so if you try to connect with Simplify3D, Simplify3D will get an error since the printer's already connected to another piece of software!"
aristoxenus
Printer is Leapfrog Creatr single
OS is Windows 7 Home Premium 64 bit
I have Windows 7 Professional 64 bit on another partition but have not tried to install anything there
Baud rate is set at 11520
The port select on Simplify shows \\,\COM4 I can change the COM number but nothing else
Arduino is installed
I have had the printer working before but this time I am nowhere
I tried Repetier but get the same results.
KeyboardWarrior
You may need to uninstall your current drivers and install the ones from LeapFrogs websites. I think there are occasions where FTDI compatibility is less than optimal/universal.
