Build plate size for D4S
Posted: Wed Jun 17, 2015 3:19 pm
by PinballGeorgio
The Build plate size in the Wanhao D4S profile is too small. Had some prints from Thingiverse made for a D4S but were a bit too big for the Build Plate. So I measured the plate and filled in the following values under Tools > Options > Machine.
Must be X-axis: 220mm
y-axis: 140mm
z-axis: 150mm
After this I can print all the files.
Re: Build plate size for D4S
Posted: Wed Jun 17, 2015 4:16 pm
by KeyboardWarrior
PinballGeorgio wrote:The Build plate size in the Wanhao D4S profile is too small. Had some prints from Thingiverse made for a D4S but were a bit too big for the Build Plate. So I measured the plate and filled in the following values under Tools > Options > Machine.
y-axis: 140mm
z-axis: 150mm
The current volume is 220x140x150 . I believe you mean that the X-axis should be 225?
Posted: Wed Jun 17, 2015 4:19 pm
by DarthRevan
Their website lists the build dimensions as: 225mm x 145mm x 150mm. But who really needs that 5 x 5 square at the other side of the build plate?
I'd use those values for it!
Posted: Thu Jun 18, 2015 2:05 am
by PinballGeorgio
Sorry, the settings are back to standard again as I checked.
The real size is 228 x 145 mm. Normally I don't need that few mm's, but came across some prints that needed this actual settings.
Posted: Thu Jun 18, 2015 9:23 am
by KeyboardWarrior
PinballGeorgio wrote:Sorry, the settings are back to standard again as I checked.
This is a good find!
Posted: Thu Jun 18, 2015 2:05 pm
by PinballGeorgio
I now have the problem that this setting cannot be saved. Everytime I start S3D and build something big I have to adjust this setting again.
Is there a way to keep this setting?
Posted: Thu Jun 18, 2015 3:14 pm
by KeyboardWarrior
PinballGeorgio wrote:I now have the problem that this setting cannot be saved. Everytime I start S3D and build something big I have to adjust this setting again.
Use the export button to export a new .fff file, then import that newly created file.
Posted: Mon Jun 22, 2015 10:16 am
by PinballGeorgio
That doesn't work. Even if I change the infill settings as example, the build plate dimensions are back to standard.
Have to correct this with every setting I make.
Posted: Mon Jun 22, 2015 10:26 am
by KeyboardWarrior
PinballGeorgio wrote:That doesn't work. Even if I change the infill settings as example, the build plate dimensions are back to standard.
Under the G-Code tab, there's the option for Override Machine Definition with settings below,
if that box is checked, it will change your build size dimensions.
Posted: Mon Jun 22, 2015 2:44 pm
by PinballGeorgio
Thanx! You're great, that did the trick!
