Vase mode problem with bottom solid layer
Posted: Thu Jun 18, 2015 10:28 am
by zippo7
Hi, I want to print some vase with a x bottom base but the gcode that I obtain has so much retraction because the slicer try to fill the hole between each layer.
Seems that the only way I can get a proper vase print is to set the Bottom Solid Layer at 0.
This is the screenshot that represent the problem:
G Code:
Settings:
Any tips?
Re: Vase mode problem with bottom solid layer
Posted: Thu Jun 18, 2015 1:30 pm
by KeyboardWarrior
If you go to the Advanced tab and turn on "Merge all outlines into a single solid model" does that help?
Posted: Fri Jun 19, 2015 4:55 am
by zippo7
Nothing, Merge was already setted in this G Code preview
Posted: Fri Jun 19, 2015 7:43 am
by jimc
Please post the factory file
Posted: Fri Jun 19, 2015 12:27 pm
by zippo7
Dropbox link to download the FFF file:
https://www.dropbox.com/s/tp3v3pd1msgnn ... e.fff?dl=0
Posted: Fri Jun 19, 2015 12:32 pm
by DarthRevan
could you please post the model file as well?
Posted: Fri Jun 19, 2015 12:35 pm
by zippo7
Posted: Fri Jun 19, 2015 12:47 pm
by C-line
If you have the Wipe option enabled, turn it off. Wipe often causes strange issues with Vase Mode.
Posted: Fri Jun 19, 2015 1:23 pm
by DarthRevan
I'd suggest turning your layer height down to .13 mm. That seemed to remove all unwanted travel and retraction moves.
