Robo3D R1 and Extruder issue: no filament out.
Posted: Fri Jun 19, 2015 8:34 am
by sev7en
Good afternoon,
I purchased today a license for Simplify3D to use it with my Robo3D R1 and firmware 3.0. The application looks amazing but I have that problem: when it start to print the filament doesn't go out. It do the object properly as far as I see but without filament.
It is not a problem of the filament because if I use the bundled MattleControl application, it works. What's can be that issue?
Regards,
Re: Robo3D R1 and Extruder issue: no filament out.
Posted: Fri Jun 19, 2015 10:04 am
by KeyboardWarrior
I think the new Robo 3D firmwares may have some temperature firmware limitations. I would make sure that you are printing at the same temperature in both programs.
For instance, printing at 190 C may be "too cold" for the Robo 3D firmware and therefore you wouldn't see any extrusion.
If you print at 215 C in Simplify3D does that work?
Posted: Fri Jun 19, 2015 12:49 pm
by sev7en
Good afternoon,
the firmware I have is the Robo3DR1V3_06112015, I set also 220 as temperature for the extruder but I had the same un-success... what really can be?
Posted: Fri Jun 19, 2015 12:54 pm
by KeyboardWarrior
In your test prints have you gotten any filament to be extruded?
What if you put the line below in the starting script of your G-Code (this will move towards the center and push out 50 mm of filament to test if the nozzle is jammed)
G1 X100 Y100 Z10 E50 F300;
Posted: Fri Jun 19, 2015 12:57 pm
by sev7en
Yes, by using MatterControl it works... in the startup g-code I have only that: G28 ; home all axes
Posted: Sun Jun 21, 2015 9:26 am
by sev7en
Good afternoon,
just tweaking the temperature as suggested, it started to print but why the quality is so poor? It's nylon...
Posted: Mon Jun 22, 2015 6:07 am
by JoeJ
You just need to adjust things so that the first layer is properly squished. They have a nice tutorial about a lot of different options to help with that here: https://www.simplify3d.com/support/tuto ... rst-layer/
Posted: Wed Jun 24, 2015 8:53 am
by sev7en
Thanks to your support and the outstanding technical support by email of Simplify3D... the issue was about the temperature of the extruder and bed, now 240 and 80 degree.
Posted: Fri Jun 26, 2015 1:12 am
by sev7en
Good morning,
as that community is.. fantastic :p I would point out that issue... why? I have ALWAYS that problem anytimes I change the filament and sincerely I do always the same operation. There is a way to do for the proper setup?
Posted: Sun Jun 28, 2015 5:27 pm
by bob64
sev7en, make sure that the filament is going into the hole below the hobbed bolt before you close the latch...
