Printed Model has a gap. Why?
Posted: Fri Jun 19, 2015 12:12 pm
by dvation
I'm having a hell of a time printing this robot hand. I'm getting a gap at the top (circled in red) and I don't know why:
Any advice? Factory file attached.
Layer Height: .1mm
Solid Top/Bottom Layers: 4
Perimeter: 2
Fill: 100%
Re: Printed Model has a gap. Why?
Posted: Fri Jun 19, 2015 12:37 pm
by KeyboardWarrior
I think the model had non-manifold edges. Slicing the model attached(repaired) worked better when I tested.
Posted: Fri Jun 19, 2015 1:38 pm
by dvation
Thanks for taking a look! What method did use to fix it? I'd like to know for future reference.
Also curious how you were able to find it - at least in the Simplify3D preview it looks like there are no gaps at all.
Posted: Fri Jun 19, 2015 1:39 pm
by DarthRevan
I typically recommend and use https://modelrepair.azurewebsites.net/
Posted: Fri Jun 19, 2015 1:49 pm
by dvation
DarthRevan wrote:I typically recommend and use https://modelrepair.azurewebsites.net/
Do you generally run all your models through that service before printing or wait until you see a problem first? Have you ever had it "fix" something that actually *created* a problem that didn't previously exist?
Posted: Fri Jun 19, 2015 1:52 pm
by DarthRevan
I generally use that site when I can't otherwise explain why something is happening. If the issue can't be linked to my settings, or my machine, then it's typically the model.
