Page 3 of 4
Re: Complex infill managment needed for large prints!
Posted: Wed Jun 01, 2016 9:41 pm
by cpirius
This is a great idea. I would really appreciate this feature being added.
Posted: Thu Jun 02, 2016 12:05 pm
by designfactore
I think the easiest fix is to enable support generation on the inside, the same way that it works on the outside. The software is already smart enough, it knows the outside from the inside already! So we just need an option to enable internal support, as well as manually place new or remove existing supports. Would be great if the inside support could have its own separate settings too
Posted: Tue Jun 14, 2016 4:11 am
by Vasily
Great idea, my vote +
Posted: Wed Jun 15, 2016 9:18 am
by Count_Carstein
Vote +1
Posted: Thu Jul 07, 2016 1:38 pm
by drolph
I'd like to add my vote - manually adding a process break at every re-entrant curve is a right pain
Posted: Sun Jul 17, 2016 3:19 pm
by pjones
+1 for this improvement
Posted: Tue Jul 19, 2016 5:37 pm
by pjones
+1
Posted: Thu Jul 21, 2016 3:57 pm
by washout661
I would like this, especially if you could define a max infill %, min infill % and a Thickness, ie dist between max and min so the density of infill is highest nearest walls & top/bottom and lowest in the centre where material is adding nothing than weight & cost. eg Max 30% min 10% with a thickness of 10mm. Would prob work best with a rectilinear / grid or a concentric circle & spoke style infill.
Posted: Wed Nov 23, 2016 2:42 pm
by aaronbarker
+1
Cura just got this in 2.3 and it is awesome. Already missing it
Seems that similar logic to the "dense support layers" could be used. What I specifically want it for is just to support flat top layers that need something under them, not for strength for the whole print. So exactly the situation of the initial post and image.
Posted: Thu Feb 01, 2018 4:27 pm
by DavidWSmith
+1 on this idea.
