[SOLVED] Export in FFF settings erases custom settings
Posted: Sat Jun 20, 2015 3:43 am
by KDan
Some of the settings in the Print quality and Material sections in the xml file are being wiped out when a profile is modified and exported. I noticed that the PLA section was defined but empty, same thing with the Medium print quality section.
I can edit the xml file manually and it then works fine, but if I export the profile - BAM! It wipes out those settings again.
Can someone else please confirm this behavior?
[edit - other comments deleted to reduce distraction - hopefully this will draw more attention to the problem described above]
Re: Export in FFF settings erases custom settings
Posted: Mon Jun 22, 2015 10:55 am
by GregGran
Bump
Posted: Thu Jul 16, 2015 4:43 pm
by KDan
This issue is basically resolved since version 3.0.
Thanks.
