Stoertebeker
Z-OFFSET ISSUE
i just finished my auto leveling setup (MARLIN, K8200). I would like to set the Z-offsett by using the simplify3d settings (not the settings in the
firmware). Unfortunately, the z-offset (in the G-Code setting-tab) doesn't work. The printer is using the settings which i configured in firmware and
seems to ignore the setting in simplify3D. Could anybody help me please? Is there a setting in the firmware, which causes that my printer ignores the
settings in simplify3d? Many thanks in advance.
stoertebeker.
Re: Z-OFFSET ISSUE
The gcode z-offset in the software moves all gcode coordinates by that amount. So for example, if you entered 0.2mm, the entire build would be raised by 0.2mm. It definitely works, I use it all the time.
