vase setting
Posted: Sat Jun 20, 2015 5:30 pm
by efes
hello
I can not print properly vase
help please
please look FFF setting please attach vase stl
tancks
Re: vase setting
Posted: Sat Jun 20, 2015 9:50 pm
by jimc
advanced tab, turn on merge all outlines into a solid model. use zero top layers.
Re: vase setting
Posted: Sun Jun 21, 2015 6:15 am
by efes
my setup FFF
please help
the extruder is not working continuously?
he makes stop during working?
there are hollow on the vase?
Re: vase setting
Posted: Sun Jun 21, 2015 8:01 am
by efes
Re: vase setting
Posted: Sun Jun 21, 2015 8:54 am
by jimc
using your fff it slices just fine for me and look good in the preview. one thing i notice though is there is too much overhang with this model. first layer looks good but when it starts to print the perimeter on layer 2, the perimeter has almost nothing under it. that perimeter is printing over air. it didnt start to look good until i got the layer height down to .1mm. you might want to reduce the layer height to .1 and try again. also your nozzle is .4 and you have your extrusion width set to .4mm. this is a little too low. the extrusion width should be higher than your nozzle width. turn that on auto or set to an even .5mm. too low can cause spotty extrusion in high overhang or unsupported areas.
Re: vase setting
Posted: Sun Jun 21, 2015 9:53 am
by efes
I miss parts because of warping
solution no warping ?
Re: vase setting
Posted: Sun Jun 21, 2015 1:59 pm
by jimc
do a search on here or any 3d printing forum. that subject has an endless amount of posts concerning adhesion for the plastic you are using.
Re: vase setting
Posted: Sun Jun 21, 2015 5:36 pm
by efes
coooool
I managed all thank you very sure but it is very fragile it is normal? me was a presion his breaks?
ABS ESUN 1.75
Re: vase setting
Posted: Sun Jun 21, 2015 9:20 pm
by jimc
sure its fragile. its only a single wall, less than 1/2mm thick.
Re: vase setting
Posted: Sun Jun 21, 2015 10:06 pm
by dsegel
If you make the model solid you can specify 4-6 perimeters and 0% infill for stronger walls. As jimc said earlier, "advanced tab, turn on merge all outlines into a solid model. use zero top layers." This is different than vase mode, but accomplishes much the same thing (except the printing probably won't spiral, so quality may not be the same).
