Torture test problems
Posted: Sun Jun 21, 2015 4:19 am
by Trhuster
Hello everyone,
Quick introduction, i am not new to 3d printing however i am new to Simplify3d and a new open source printer. I tested to print out this torture test : http://www.thingiverse.com/thing:33902
My factory file is here: https://www.dropbox.com/s/jcn8r8ny1lm72 ... ctory?dl=0
As you can see the pillars is very bad and the noice when printing the pillars are quite unpleasant to say the least. You can listen to it here: https://youtu.be/VCwlxY8D_nc
I printed with Z-ABS and used 0.2 layers and 40mm/s real speed on all perimeters. As reference you can se my 3d benchy printed very good, but then i used speed overrides under cooling tab.
Anyway, is this printer fw problem or a simplify3d problem?
Re: Torture test problems
Posted: Mon Jun 22, 2015 2:08 pm
by DarthRevan
Trhuster wrote:As you can see the pillars is very bad and the noice when printing the pillars are quite unpleasant to say the least. You can listen to it here: https://youtu.be/VCwlxY8D_nc
You're already printing pretty slow, but for an object of that size with circles that tiny, you probably want to slow down even more. I'd suggest trying out 20mm/sec. You could even just set the perimeters to that speed since the infill isn't visible. Outline Underspeed to 50% would do the trick, and should also help with the noise.
I often find this guide helpful. Despite it being tailored for Cura/Ultimaker, the principles of getting better prints still apply.
