Mendel Max 1.5 profile and print footprint woes.
Posted: Tue Jun 23, 2015 11:02 pm
All, Im still having challenges setting up my virtual foot print. in regards to the actual print platform and what shows on the screen.
MY machine is a Mendel Max 1.5.
the print bed actual print surface is 230mm x 290mm Lets assume the bottom left of the print surface is X0 , Y0
My extruder (X Axis) will actually move about 20mm off the X print surface. So lets call this X -20.0
and the Print surface will move about 40MM below the Y axis. So lets call this Y -40.0
I did not see a MendelMax 1.5 in the new 3.0 release.
Software Ver: Im running the new 3.0
Wish I could change.
1: How could/can I get the UCS icon to end up at the Table 0,0 not the actual real world 0,0
this way when I see the build platform in Simplify3d what I see is what is useable.
Right now what I see is actually bigger than I can use. so i must be careful when placing parts near the edge as they will try and print way off the edges.
Not sure what to else add
Help?
Sam
Help?
Sam
