LWSSOLO
Re: FFF file location?
Fri May 19, 2017 8:48 am
Hope this is usefull to some of you. Worked for me but try at your own risk.
My win10 installation crashed irrevocably after an automatic update (..grrr Microsoft) and along with every other program and settings (data was on separate drive) I lost my painfully configured FFF settings for my three custom built printers. No backup of those....
So this is what I did.
Installed a brand new ssd for the freshly installed Win10. Left the old disk untouched with the bricked system on it for the moment.
(thanks to NEUTRON16 whose istructions I followed :https://www.sevenforums.com/general-dis ... stall.html)
(But as long as you still have access to the old drive or a Registry backup either of those would work)
Since Simplify stores it's settings in the registry I thought it could work for me as well:
Press Start obr - type REGEDIT, open it.
Open HKEY_LOCAL_MACHINE, then File - Load HIVE.
Browse your old hard drive DISK:\Users\%USERNAME%\, highlight file
NTUSER.DAT and open it.
That is HKEY_CURRENT_USER of your old Windows.
It will ask you for a Key Name, enter 123test
Now you will see that HKEY_LOCAL_MACHINE has got a new thread - 123test.
That is actually old registry mounted.
Go to 123test\Software\simplify3d, right click Export. (give it a name and save to any location)
Then click head thread 123test, and File - Unload Hive.
Open exported reg file in NOTEPAD. Edit - Replace, replace all
HKEY_LOCAL_MACHINE\123test\Software\Simplify3d
with
HKEY_CURRENT_USER\Software\Simplify3d
save that reg file and run it.
This process reloaded all my FFF profiles!!! and all seems to work fine.
tobyCwood
Thu May 25, 2017 3:20 pm
Its been awhile for this thread but it needs to be revisited. WHERE ARE THE PROFILES?
When we upgrade to a new S3D the profiles are there in the new version this seems to indicate since older versions are retained that the profiles are saved somewhere. Yet when my iMac recently died and I restored my apps from my backup... no profiles.
So... are the profiles saved as resources within the app package? If so why didn't they come over in the restore???
Thu May 25, 2017 5:33 pm
Does my post here help answer your question??
viewtopic.php?f=8&t=7449&p=32468#p32468
boyan
Tue Feb 26, 2019 8:26 am
Great! Just saved my day :D
ha1f3mpty
Sun Jun 09, 2019 10:10 pm
This is for a Windows machine, I do not have a solution for any other operating system.
I know this is an old post but it didn't have a solution. I was messing around and found some other posts talking about this registry location, again not marked as a solution to backing up Simplify3D settings or migrating between systems, so here it is. First off if you don't understand what comes next then you probably don't want to mess around with this because if you mess up the registry then you can mess up your machine. You want to open the registry editor, find this key HKEY_CURRENT_USER\Software\Simplify3D and export it. Then just merge to your system after bare metal restore or to another system.
