Importing Small Scaled models.
Posted: Wed Jun 24, 2015 6:53 pm
by dodgersfan24
Usually I create and edit models with blender. I set it to metric, and scale to 1. When I import my STL's, it says
Part appears to be extreamly small and may be in inches format. Would you like to automatically scale to millimeter format?
I click no as always, then change scale from 1 to 1000. And go from there.
But now in 3.0 it scaled at 100, and cant increase it to 100,000. I can only do it to 99999.00,
Is this an issue for anyone else? Can I fix this in blender side?
Re: Importing Small Scaled models.
Posted: Thu Jun 25, 2015 9:27 am
by KeyboardWarrior
dodgersfan24 wrote:Usually I create and edit models with blender. I set it to metric, and scale to 1. When I import my STL's, it says
If you export your model in mm units for the STL, then it shouldn't need to be scaled once in Simplify3D
Posted: Fri Jun 26, 2015 3:29 pm
by dodgersfan24
Thank you, that helps.
