dragonf1r3
External Infill ignores infill angles
In 2.2.2 external and internal infill (was it broken out?) both used the same infill angles that you specified in the process settings. In 3.0 external infill is ignoring those angles and only using +/- 45. I verified this by setting 0 top layers and setting it to 100% infill. I had setup 0/45/-45/90 and 4 top and bottom layers in 2.2.2 because I really liked the look of the 0 and 90 on the top and bottom of a print. Does anyone else have this problem? Is there a way to fix it?
MichaelHerron
Re: External Infill ignores infill angles
dragonf1r3 wrote:In 2.2.2 external and internal infill (was it broken out?) both used the same infill angles that you specified in the process settings. In 3.0 external infill is ignoring those angles and only using +/- 45. I verified this by setting 0 top layers and setting it to 100% infill. I had setup 0/45/-45/90 and 4 top and bottom layers in 2.2.2 because I really liked the look of the 0 and 90 on the top and bottom of a print. Does anyone else have this problem? Is there a way to fix it?
Posted in bugs forum. Im having the same problem.
