Support settings (separation layer) depending on steepness
Posted: Thu Jun 25, 2015 2:55 am
by Sirnicha
Hello at all,
I switch the "separation layers" to zero when I get into steep areas (50° to 70° from vertical) which need support. I experienced often edge curling when a separation layer is used, because the edges don't really stick at the support.
It would be very nice to switch the support settings either depending on the steepness of the part or to define manually regions at the part where the support options can differ.
In my case the option to create different processes (with different support options) often doesent work, because regions with different steepness overlap.
Would this be possible?
Thanks,
Felix
Re: Support settings (separation layer) depending on steepne
Posted: Thu Jun 25, 2015 12:02 pm
by bone
+1
I have this same problem also.
